Results 1 to 7 of 7
Thread: V6 Tuning, Megasquirt2 vs Delco 808
    simc is offline Supercharged V6 Gemini
    Jul 2005
    Default V6 Tuning, Megasquirt2 vs Delco 808
    Hey guys.
    In the near future ill be needing to do some engine management tweaks to keep up with the mods.
    Just trying to decide what platform I should go with. I want something i can tune myself as my mods change quite often.
    Convert to Megasquirt2, there is a heap of info around for it, and the real time readouts/data log functions will come in handy. Also seems like there is a heap of help available on the site forums is there are any issues.
    Or play around with the Delco 808. Obviously people out there are having good success with this, however the info on this is far less available and straightforward. My searches have only ever given dribs and drabs of info.
    Opinions?
    Current Rides - The Daily: BA XR6 Turbo -The Scary One: TE/G Gemini Supercharged 3.8L V6
    The Cruiser: 1966 XR Fairmont V8 - On Two Wheels: Honda XR250R - The Wifeie: VZ Wagon
    Shortstuff's Avatar
    Shortstuff is offline Random
    1995 VR II V6 Wagon
    May 2006
    I'd go for the Megasquirt2 for the simple fact (as you said) there is a lot more help / info available for it and I have only heard good things about it so far.
    Whoever said 'There is no substitute for cubes' had obviously never heard of Jet power
    VP Exec
    Jun 2005
    The advantage with the '808 would be that a lot of the programming is already done and it is much more sophisticated with lots of additional variables, which may or not be good thing.
    hakhawk's Avatar
    hakhawk is online now smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    v6 or v8? the megasquirt 2 doesnt have a good elec ignition setup for the v6 yet, but foor the v8 it should be fine, as itss still just singlle coil.
    but there has been a few people doing some crazy stuff to the delco unit.
    vl400 a member on here is part way through getting a realtime tuning setup done, the hardware is done, as i have it sitting inn my shed, but hes still working on thhe software.
    it also converts the 808 delco from 160 baud data readout to the vr 8192 data speed.
    the megasquirt2 would be a awesome diy project, but ive gone the delco route.
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    If it's a manual why not just run the VR computer as it is?
    Gravity is proof that nature keeps getting us down.
    Jul 2005
    Does the VR ECM plug into the VP loom?
    At present I dont have any signal inputs from the auto to the ECM, I dont use the converter lockup or the speedo signal, so could be treated like a manual.
    Its a V6. I was under the impreson that the MS2 worked on basically any engine. Any more info on the issue wih the V6 ignition ?
    hakhawk's Avatar
    Jan 2005
    it does, but its only really fuel control, hence the name megaSQUIRT, and sensor control, the ignition side is still very basic, but they are working on better control.
    im not sure whta it is exactly that doesnt like the v6 coilpack, but its something to do with telling it when to spark.
  1. delco remy
    By Bunjey in forum Electrical Wiring / Questions
    Last Post: 14-03-2007, 08:05 PM
  2. delco or bosch?
    By Farlig in forum V6 Development And Modification
    Last Post: 26-02-2007, 07:14 PM
  3. DUEL Maps On A Delco ECU???
    By defa in forum General Discussion
    Last Post: 08-02-2007, 08:02 AM
  4. Remanufactured Delco 808...
    By g00gz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-03-2006, 01:27 AM
  5. Delco Query
    By milz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-01-2004, 11:26 PM
