Results 1 to 6 of 6
Thread: VN Intermitant stalling/won't start
    VN Ex-cop car
    Mar 2006
    Default VN Intermitant stalling/won't start
    After a short drive the other day my VN wouldn't start after 10mins I went back and it started 1st pot. Then 5 mins down the road i kicked the throttle it lit up then spluttered and konked out! another short rest and it sprang back to life. Two days have passed and driving it is a tender task. I've sat and got the car hot (1/4 temp the hottest it gets) and stopped the motor and restarted it with no probs most of the time so i dont think heat is a contributing factor. Don't know where to start my bro says fuels pump how can u tell? all help would be greatly appreciated:>)
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    Hmm Could be a number of things....I had a very similar problem.....Was the fuel pump in end....
    OK so what happend to me was i could drive for bout 10-15 then i would start to loose throttle (wouldnt be able to use more than 1cm of throttle) if u put ur foot down too far it would stall even @100km...
    Went to mech, he said deffiatly a Crank angle sensor prob, so changed it, got 15min drive did it again, went bak he said it may be a dodgy crank angle sensor so he changed it again for free, did it again so i told him to check the fuel pump as when it playd up the pump was really loud n wouldnt stay at the same tone.....
    He did a pressure test n it was fine cept that it would loose pressure after car was turned off, so i told him to change it anyway, picked up car n didnt have another problem....
    So if ur fuel pump is gettin really loud n not stayin at same tone id say its ur pump but if u can throw a bucket of water on the crank angle sensor and it starts straight away then that would be the problem....
    Hope this can help in any way....
    ________________________________________
    92 VP Calais 3.8
    May 2006
    Gold Coast
    Ohh when it doesntstart does it stink when u try to turn it ova, coz mine had a weird smell when pump wasnt pumpin properly
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    sounds like it could be a fuel supply problem, change the fuel filter first (only a couple of bucks) and see how that goes. check all the other usual suspects too, like a battery and alternator test (probably isnt this, but doesnt hurt to check) you can get them done at auto parts store for free (like autobarn, supercheap,etc.)
    VN Ex-cop car
    Mar 2006
    Cheers my bro is down in 30 mins to do the work we have a few spares to change over but will start with the pump let you know and thx again. TOP FORUM SITE!!
    VN Ex-cop car
    Mar 2006
    nah no smells at all or smoke froms the car atleast!!
    Taking her for a cruise now and hopefully the new pump has fixed the issue!
  1. stalling on first start
    By Berlinarator in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-03-2007, 09:43 PM
  2. intermitant transmission problem
    By achimw in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-10-2006, 08:37 AM
  3. Start Then Stalling
    By micko in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-04-2006, 09:59 AM
  4. Can't start cold except for clutch start.
    By Holdfast in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2005, 07:30 PM
  5. intermitant engin fail
    By Spin in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-08-2004, 01:47 PM
