Results 1 to 3 of 3
Thread: aftermarket temp guage into vn
    '89 VN Commodore
    Feb 2004
    Hobart, TAS
    Default aftermarket temp guage into vn
    Hi,
    I have an aftermarket water temp guage in my vn which was already in it when i bought it... i checked where it was wired to and it is joined to the wire from the engine temp sensor just next to the thermostat (series 1 motor) anyways so the sender was trying to send a signal to both guages so the guages barely moved anyway i cut the aftermarket guage wire and now my temp guage on the cluster is working fine. But i would still like to have the aftermarket guage working aswell (it changes colour n stuff so its cool) now i was thinking... i read in the gregorys workshop manual there is a coolant temp sender just below the engine temp one... so if i unplugged that and wired the aftermarket guage to it would it stuff up my computer?
    -commodore - holdens driving future and for those who dont like the scenery-
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    Yep it would. The second temp sensor is the one which runs to the computer. Unplug that and your computer won't know what temp the engine is at.
    You're probably better off either picking one temp gauge or the other. Failing that, if you really need to see your temperature twice on the dash you should be able to pick up a t-piece adaptor that will screw in to the hole that the GAUGE temperature sender sits in, then you can screw the sensor for the cluster gauge into that, and (into the other hole on the adaptor) you should be able to screw another sensor for the aftermarket gauge.
    But ask yourself, do you really need to see the water temp twice?
    Gravity is proof that nature keeps getting us down.
    '89 VN Commodore
    Feb 2004
    Hobart, TAS
    yeah true... oh well might aswell just use the aftermarket one
  1. vs aftermarket guage install
    By westoz in forum General
    Last Post: 11-09-2007, 09:37 PM
  2. low temp on guage?
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-06-2006, 04:36 PM
  3. temp guage
    By dig3283 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-04-2006, 02:37 PM
  4. second temp guage
    By chevy_big_block_bro in forum Electrical Wiring / Questions
    Last Post: 10-11-2005, 04:57 PM
  5. temp guage
    By vpdood in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-09-2004, 05:08 PM
