Results 1 to 11 of 11
Thread: Shudder
    VN COMMODORE V6
    Oct 2005
    Johnsonville
    Question Shudder
    Hey all. When say sit on a 100 and i slightly let go of the pedal the whole car will shudder. I cant seem to work it out but i only seems to do it at around 100.What could it be. I was thinking it could be the gearbox but i dont no!!!
    Thaks guys
    VN Calais no more
    Sep 2006
    Wheel alignment, or at worst case it might be the bushes.
    Take it and get a wheel alignment done, and see what happens from there.
    Also, if you have retreads or poor tyres, occasionally these can become oval shaped, so this might make the car unstable.
    I wouldn't be be concerned about the gearbox otherwise you would be having troubles way before 100kmph.
    xcop5l's Avatar
    xcop5l is offline 4th year spanner spinner
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    check your tail shaft uni joints and center bearing.
    Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
    MY RIDES
    [SIGPIC][/SIGPIC]
    http://forums.justcommodores.com.au/...ad.php?t=41837
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Quote Originally Posted by xcop5l View Post
    I second xcop5l's suggestion..
    Dan355's Avatar
    Dan355 is offline Go THE SS's
    Street Legal 355ci VN SS - Daily: VP SS
    May 2006
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    not likely at that speed, but theres a possibility that its the converter slipping.
    it makes a terrible shudder throughout the car and a slight noise.
    VN COMMODORE V6
    Oct 2005
    Johnsonville
    well thnaks for all your thoughts i will have to have a look into them untill i can work out what it is. I had a thought of the wheel alignment. But thanks
    2greedy is offline VP Calais (SSV)
    VP CALAIS (SSV)
    Apr 2006
    Queensland
    i'm having same problem but seems to be at about 120 onwards to about 140 but i havn't noticed if it goes out of it after that speed if it does i would have to say uni's or center bearing?
    VP Executive S2 3.8L
    Oct 2006
    Kingston
    Quote Originally Posted by 2greedy View Post
    Where do you drive at 120-140kph?
    VC Twin Turbo, VN Turbo, VY Storm
    Oct 2006
    To make sure its not the trans just unplug the plug on the passenger side of the transmission it is the lockup. It wont do anything but maybe use a little more fuel on the freeway.
    Jul 2005
    Default Vt ss shudder in reverse
    I HAVE A 98 VT SS MANUAL SEDAN AND HAD A NEW CLUTCH PUT IN THIS WEEK & EXTRACTORS FITTED, NOW WHEN ITS IN REVERSE IT SHUDDERS! SOMEONE SAID THEY EITHER HAVNT MACHINED THE FLYWHEEL OR THE FLYWHEEL HAS A FLAT/HIGH SPOT IN IT & THEN SOMEONE ELSE MENTIONED ENGINE MOUNTS. SURELY WHEN THEY DROVE IT OFF THE HOIST IN REVERSE THEY NOTICED IT?
  1. car shudder
    By kunifa in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-05-2007, 09:30 PM
  2. VT shudder
    By MrE in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-03-2007, 05:19 PM
  3. bad shudder
    By 2greedy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-03-2007, 10:12 AM
  4. Shudder on Take off
    By Harvs82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-02-2006, 09:32 AM
  5. Brake shudder???
    By PaulW in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-10-2005, 11:08 PM
