Results 1 to 9 of 9
Thread: Spark Plugs becoming faulty when Air Con is Turned On
    VT SS 5.7L Commodore.
    Feb 2004
    NSW, Australia
    Default Spark Plugs becoming faulty when Air Con is Turned On
    Hi,
    I have a friend who when is driving around town, if he turns the air conditioner on, his back two cylinders (V6) spark plugs let go, that the engine only runs on 4 cylinders, he then has to have the spark plugs replaced. Now if he uses the Air Conditioner on the highway, he has no problems. His mechanic just says this is a common fault with the Series I VP Commodores.
    I just can't think of what could be causing this problem?
    Thanks,
    Yours Kindly,
    Jim
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    I'd say find a new mechanic. I've never heard of that on ANY car.
    Gravity is proof that nature keeps getting us down.
    VN v6 s2 Berlina 5spd
    Mar 2006
    im interested, wat do u mean let go?
    u mean the plugs fall out the block or break?
    are the spark plug threads allright?
    ive gotta problem with my no1 plug/lead
    once a month the lead will pop off the plug,
    and sounds/runs like a 50 year old yank tank
    i beleive this is due to the lead.
    mouce's Avatar
    Jul 2005
    ^^^If you're dropping leads like that, just get a new set, they don't cost that much.
    VN Commodore
    Feb 2006
    thats sounds a little bit strange.. even if there was some sort of electrical fault how could that stuff up ya plugs. that just doesn't make sense at all..
    also what do you mean by the spark plugs letting go..
    Feb 2004
    NSW, Australia
    Well, the dude that owns the car isn't very mechanically minded, all he knows is the mechanic has to replace the back two spark plugs. I just assume they stop working, which doesn't make sense, and yes I thought too as how can an electrical fault fail a spark plug?
    Yours Kindly,
    Jim
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    sounds like you mean fouled plugs??? need more info
    Body by Holden, Soul by Brock
    the Legend will live forever
    Feb 2004
    NSW, Australia
    Yeah problem is his mechanic didn't or doesn't tell him exactly what happens to the spark plugs just says they need replacing, mind you this has happened more then once.
    He know just doesn't use the air con around town.
    Yours Kindly,
    Jim
    Apr 2006
    Auckland NZ
    Quote Originally Posted by mouce View Post
    you nailed it here
  1. Replies: 25
    Last Post: 05-02-2011, 07:52 PM
  2. best spark plugs to use
    By jamo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-09-2006, 10:01 PM
  3. Spark plugs what do you use?
    By Spaced in forum Just Commodores Polls
    Last Post: 04-08-2006, 01:21 PM
  4. No Spark /Fan goes when key turned on.
    By tigerfire in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-12-2005, 06:48 PM
  5. Spark Plug Leads Getting 'baked' on to Spark Plugs?
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2005, 04:16 PM
