Results 1 to 11 of 11
Thread: Some stage-2 shift kit questions
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Default Some stage-2 shift kit questions
    Alright, I've had a good squiz at the forums, and I havn't found any concrete answers that made me happy, so here's a pile of great questions that I'm hoping some mech-nerd can answer!
    True or False:
    1) a stage-2 B&M shift kit will cost me about $120 for the parts
    2) a good mechanic can install this for me in about 3hrs
    3) my gear changes will be sharper, and faster
    4) gears will change almost instantly when I pull the stick down from 3rd to 2nd
    5) with the stick in 2nd, my car will still launch from the lights in 1st
    6) wear on my gearbox will remain a non-issue as long as I don't rip her into 1st doing 60kph
    Short-answer
    1) with the shift-kit, which gears change like a manual (going up and down). i.e. if I'm doing 50 in 2nd gear, still giving it a stack of throttle, and I pull up into 3rd, will it shift, or stay in 2nd where it belongs?
    1) what are these corvette servos I hear people talking about
    2) what do they do
    3) how much do they cost
    4) pros/cons versus price
    God bless whoever answers these questions. I'd ask a mechanic, but they always seem to have some sort of vested interest in the answers they give.
    The 1972 HQ Kingswood
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    i dont know how much i like to be this "mech-nerd" that answers you, but anyway, lol.
    true/false
    1) true....but a transgo shiftkit is better
    2)true
    3)true...they will be very crisp and anything over 1/2 throttle will launch into gear (ie, probably chirp wheels)
    4)true
    5)hmmm, not too sure about that one, a stage 2 has full control of gears, so whatever gear your in, thats what it will be in to any rpm.
    6)wear on bands and 3/4 clutch will decrease, true
    short answer
    1) all gears will, stage two has full manual control back and forth....untill you put it in "d" and it will be like normal changing automatically (the difference between stage 2 and stage 3)
    1) (hey, you put 2 Q 1's) they are exactly that, a servo piston that was used in corvette 'boxes
    2) they are are bigger/better design of the ones found in your 'box atm, they have a larger surface area to hold the band with greater force under pressure, giving you a harder firmer shift.
    3) around $30 each
    4) there are none, they are one of the best things you can do for your transmission on a budget.
    Jun 2005
    id be interested in prices of parts and installation of a transgo kit
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    xcop5l's Avatar
    xcop5l is offline 4th year spanner spinner
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    Quote Originally Posted by Morton View Post
    True or False:
    1 true
    2true
    3true,with wheelspin into second
    4true
    5true, what ever gear you are in form a standing start it will always start in first
    6 it has a slightly higher wear rate but not enough to worry about
    Short-answer
    2) what do they do
    1 the auto will still change like an auto if its in drive,if you put it from 2nd-3rd at 50 at reasinabil revs it will change to 3rd
    2. the corvette servos just bolt into the auto. they provide a higher fluid pressure wich allows for a sharper shift.
    im not sure what they cost
    if your going to get a stage 2 shift kit dont just get a bolt on job get it done by the professionals.
    i would highly recomend DTM automatics in geelong they build race transmitions. they built the whole shift kitted auto in my cousins vn and that thing is now a weapon
    by the way i am a mechanic
    Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
    MY RIDES
    [SIGPIC][/SIGPIC]
    http://forums.justcommodores.com.au/...ad.php?t=41837
    Morton's Avatar
    May 2006
    bloody aswesome, sircruisealot and xcop I now understand exactly what these shift-kits are on about better than ever!
    I think I'll seriously look into getting one thrown in next time I do an auto service. May your own personal gods bless you both individually. \o/
    time to start saving. lol
    edit: reputation added for you two. Cheers again for the effort
    VX II Calais L67
    Dec 2005
    Yeh i'm getting a stage 2 and corvette servo installed, although i'd like to hear opinions on why Transgo is better, as far as i've seen so far (which is not much) people rate them about the same.
    Aug 2004
    not going to be much difference as the transgo kit is just a modded seperator plate?
    shift kits are good yes get one and if you dont mind a bit of a bump when it changes gears it great
    Morton's Avatar
    May 2006
    That's an interesting point, 'cause the transgo kit does cost a tank of gas more than the B&M.
    Actually, here's a question: if I get a shift-kit installed, can I keep my current gear selector? Or will I have to upgrade to one of those akward-looking metal sticks?
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    You keep your current gear selector..
    Thats a SHIFTER you are thinking of. Also made by B&M... Some of em are alright, but most are too bulky. If they'd fit in the stock hole it would be much better.
    Morton's Avatar
    May 2006
    Ahh. awesome. thanks chief ^^
    VX II Calais L67
    Dec 2005
    Yeh the B&M doesn't come with the plate, you have to modify your existing one, which may be the reason for the price difference. I'm yet to hear of any noticeable difference between the two yet.
  1. stage 2 shift???
    By vn4play in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-09-2008, 06:54 PM
  2. stage 2 shift kit VR
    By VZHSV in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-08-2007, 05:55 PM
  3. stage 2 shift kit?
    By Sabby in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-01-2007, 12:13 PM
  4. Shift Kit stage 3
    By nmd_nathan in forum V6 Development And Modification
    Last Post: 19-09-2006, 04:18 PM
  5. vn stage 3 shift kit
    By VN-88 in forum Parts And Other Items For Sale
    Last Post: 07-05-2006, 10:24 PM
