Results 1 to 9 of 9
Thread: Temperature gauge or sensor
    VN Berlina 3.8
    May 2005
    Default Temperature gauge or sensor
    sup guys jsut a quik question my tempreature gauge aint working and im not sure if its the cluster or the senosor. firstly where do i find the sensor on a S1 vn (eg what color wire) and is there anyway to test the sesnor or the cluster ie with a mulitimeter or test light to find out what wrong.
    cheers
    JD
    JD is offline Donating Member
    VS Berlina
    Aug 2006
    Deep South, SA
    i suppose you've bashed the dash?
    probably cluster is not connecting properly, try taking it out then putting it back in again.
    We got rep back, yaaay!
    VP Executive S2 3.8L
    Oct 2006
    Kingston
    Default maybe this will help
    have you tried:
    Solution to Sticky fuel/temp guages
    they suggest the problem you have is related to some dry joints in the instrument cluster
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Yeah probly the cluster, there are threads on how to fix.... the gauge sender is found under the throttle body i think, it has a single wire coming out of it, you can take it out and see measure the resistance in different temperatures of water and compare that against the specs found in a gregories to see if its in working range, but i highly doubt its the sender, more likely the cluster.
    VP Executive R-spec
    Jan 2005
    At least on the series one. Both temp sensors (gauge and ecu) are in the back of the inlet manifold
    xcop5l's Avatar
    xcop5l is offline 4th year spanner spinner
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    Quote Originally Posted by vn6pwr View Post
    if you put this wire to earth/body the gauge will read verry hot.
    this will pove if your temp gauge is working
    Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
    MY RIDES
    [SIGPIC][/SIGPIC]
    http://forums.justcommodores.com.au/...ad.php?t=41837
    m3taL's Avatar
    m3taL is offline For what its worth.....
    88` S1 VN, 5spd & 94' VR Wagon
    Aug 2006
    Bendigo, Vic
    Quote Originally Posted by MyVPIsFasterThanYourVP View Post
    have you tried:
    This works good Fixed my Problems also if i was a sensor u would be getting a ECU code and ur engine light and Fan would come on atleast thats what mine done when my sensor went :P
    m3taL... for what its worth...
    http://s92.photobucket.com/albums/l9...rrent=vn-3.jpg
    My Ride
    88' VN 3.8 5spd, Custom CAi, 2.5 High-flow zaust && Foaming Tune!!!
    Turbo Manifolds and Plumbing Near completion!
    Family Ride:
    2007 Kia Grand Carnival Lux Model
    J_D
    J_D is offline
    VN S1 and VS V8 Statesman
    Jul 2006
    Ipswich. QLD
    You wouldnt get an error code if its the guage sensor as the computer uses its own sensor.
    Im not a complete idiot, some parts are still on backorder!
    m3taL's Avatar
    Aug 2006
    Bendigo, Vic
    Quote Originally Posted by J_D View Post
    does it?? In S1 the one on the top under the Throt body with the single green wire is the Sender to the Guage??? and has nothing to do with the ecu?? cos i snapped the top off that one a few weeks back and i went to the auto shop down the road and got another and when i put it in i got the code for Temp sensor Voltage too high then the fan stayed on and it carried on like a fool then i went to pick a part n got one off another vn changed it with the Suspect one and hey presto no error codes again...... maybe it was just throwin the voltages out or somthing........ dunno seems weird
    My Ride
    Family Ride:
  1. Temperature Gauge
    By VRsharkie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-09-2007, 07:49 PM
  2. temperature gauge
    By 12000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-02-2007, 09:59 PM
  3. Temperature Gauge
    By ivaninoz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-12-2006, 10:12 PM
  4. Vt Temperature Gauge
    By stephen in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-02-2006, 10:18 PM
  5. Temperature Gauge Faulty
    By Harvs82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-02-2006, 06:04 PM
