Results 1 to 6 of 6
Thread: my g/f's speedo, trans, stall problem.
    Ryzza75 Guest
    Exclamation my g/f's speedo, trans, stall problem.
    My girlfriend has a VP 1992 thats done 196,000.
    Lately she has been getting a problem with her speedo, at random times, just dropping from 60kmph to zero and doesnt register. This as i said happens at random times and then kicks back in at random times unless you turn off the car and start it again.
    The more worrying thing is, when the speedo dies, a few seconds after that the car starts chuggin funny and goes to stall when she brakes at corners and at lights. Its not a spluttering from the engine but more of a shuddering caused by the transmission not changing gears properly I think.
    Its getting worse as she keeps driving it, happens more regularly for longer periods and she doesnt thrash her car, cares for it like her baby.
    I was wondering if anyone here has any idea if its just a sensor messing up the computer or something? If its easy to fix/diagnose the problem? and Hopefully a ballpark cost figure?
    Its fairly urgent because if this is unfixable or costs too much we are going to sell it off and try get another car.
    Any comments greatly appreciated. Thanks guys.
    VP Exec
    Jun 2005
    Lack of speed sensor signal to the ECM will cause the stall. Most likely culprit will be the speed sensor itself - located on the back of the transmission but it might be other things such as wiring, speedometer, ECM.
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    Ryzza75 Guest
    thanks guys... anyone got any idea of a rough cost a speed sensor is? to buy and or labour to install? I dont know much about these things.
    Thanks
    VP Exec
    Jun 2005
    About 20 mins labour to fit a speed sensor, 19.5 of which will be talking to you/girlfriend, putting car on hoist and 30 seconds fitting. That is, of course, without any diagnosis time. Cost of part: ?????
    Ryzza75 Guest
    hmm ok then,... i might have to do some research on where it is and how to get to it. I'm a bit busy at the moment trying to get my air con working in my poocar.
    thanks for the help once again. I will let ya's know how I go
  1. Big problem, car audio making car stall
    By Blakie in forum Car Audio
    Last Post: 02-01-2008, 01:35 PM
  2. Auto Trans problem when hot - need a trans cooler ??
    By woteva in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2007, 11:41 PM
  3. Car Trans Problem...
    By Z()LTAN in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-02-2006, 10:07 PM
  4. VS s1 TRANS PROBLEM
    By harvs01 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-08-2005, 08:38 AM
  5. trans problem
    By sk8er in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-01-2005, 03:52 PM
