Results 1 to 10 of 10
Thread: series 1 injectors in series 2 engiine?
    Vz Sv6
    Jul 2005
    Default series 1 injectors in series 2 engiine?
    as the title states. can it be done?
    Cheers!
    Jezza
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Yeap, Im sure they will be fine. I think they are all good up to the VR, VS is ecotec so I think think they can be used.
    Aug 2004
    Yep can be done, you can use Series 2 on Series 1 engine.
    only difference with these two are Rope Seal on the crankshaft on Series 1 and rubber seal on series 2 engine..
    AP
    VP Executive R-spec
    Jan 2005
    And the heads, inlet manifold, exhaust manifolds, valve springs etc etc but at least the injectors both flow 19 lbs/h : )
    VN v6 s2 Berlina 5spd
    Mar 2006
    vnexecutive wagon
    Mar 2006
    ive just done it i just haave put a set of vr injectors into series 1 vn had them cleaned and checked car now goes like a cut cat getting 11.5 litres per 100 was getting 12-13 per 100 kms theyare better injectors holden only used series 1 vn injectors in 1 motor only they changed them in very late series 2 vn but used new injectors in vp and all later
    Keesh's Avatar
    Keesh is offline WATSON HOLDEN
    VQ 5L Caprice, WH LS1 Statesman, VN 5L Calais
    Jan 2006
    i heard someone say he had vt injectors on a vn once, can this be done, my injectors are rooted and i need new ones, should i go the vt's?
    Don't blame me, It's that damn percadan..
    If you ask me, that stuff rots your brain...
    And now a word from our new sponsor.. Percadan? oh crap!
    hakhawk's Avatar
    Jan 2005
    AklHoon is offline aklhoon
    VN 3.8 Executive
    Sep 2006
    Auckland NZ
    Hey Guys ive just fitted VR injecters to my old VN.
    Turn the key for few seconds to build fuel pressure and whalla she fired into life nicely.Not only does my old girl run alot quieter with less induction and exauste noise,but also throttle responce is improved very rapidly.
    Not bad for $24 trial for set of injectors.
    Next up is 65mm V8 throttle body,another trick of been told about is to pollish the inner of the TB and the Elbow to the inlet (faster flow)
  1. series 2 vq with series 2 vn motor, almost stalls between park and reverse and drive
    By sp001in in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-05-2011, 11:49 AM
  2. vn v6 intake manifold/head difference between series one and series 2/vp/vr
    By hakhawk in forum V6 Development And Modification
    Last Post: 06-09-2010, 12:13 PM
  3. vx berlina series 1 and series 2 whats the difference
    By rgormley in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-08-2010, 06:40 PM
  4. wrecking VS CALAIS SERIES 2 INTERIOR + VS STATO SERIES 2 DOORTRIMS
    By petezor in forum Parts And Other Items For Sale
    Last Post: 07-05-2008, 10:50 PM
  5. Convertting to a series 1 engine from series 2 AND question about oil pick up
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-10-2006, 07:37 PM
