Results 1 to 7 of 7
Thread: Mechanical Temp Gauge Installation
    anton1o's Avatar
    anton1o is offline [GMHVN6]
    VN 6 Berlina '90
    Jan 2005
    West Subs,Melbourne
    Question Mechanical Temp Gauge Installation
    Just after some help on installing an Autometer Mechanical Temp Gauge...
    Ive been to autobarn, and they have said you cannot use a T-Piece and run it into the Radiator Pipe.. Saying either into the block or thru a thermostat..
    More info/pics would be awesome if you have done this before
    Thanks!
    ride; [GMHVN6] Project Streeter - VN Berlina '90 mods; 65mm throttle-body / Cold Air Intake / 8mm Ignition Leads / Exhaust
    future; Extractors , Cam currently; 101.2rwkw mission; 110rwkw
    xcop5l's Avatar
    xcop5l is offline 4th year spanner spinner
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    i had a mechanical temp gauge (before i broke the pipe off the bac)
    a t-peice will work but but you will need to have it screw into where the temp sender screws into then screw the gauges into that
    Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
    MY RIDES
    [SIGPIC][/SIGPIC]
    http://forums.justcommodores.com.au/...ad.php?t=41837
    anton1o's Avatar
    VN 6 Berlina '90
    Jan 2005
    West Subs,Melbourne
    Do you have a picture of that spot? Are you saying the sender that is used in the dash?
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    Keep in mind that mechanical temperature and pressure gauges are defectable items if they are mounted inside the cabin.
    It is illegal to have a non-factory high-temperature or high-pressure line running into the cabin, as it is deemed dangerous in the event of an accident.
    Electrical temperature and pressure gauges ARE legal for in-cabin usage. If you're mounting it on the bonnet, then as far as I know you can use either.
    Gravity is proof that nature keeps getting us down.
    anton1o's Avatar
    VN 6 Berlina '90
    Jan 2005
    West Subs,Melbourne
    How are police officers meant to know the gauge is Mechanical..? Its going to be mounted in the Din-Slot so they wont even see the wiring comming off it..
    VN v6 s2 Berlina 5spd
    Mar 2006
    Quote Originally Posted by mouce View Post
    what about mechanical boost gauges,
    they only use a vacuum line.
    is this still defectable?
    anton1o's Avatar
    VN 6 Berlina '90
    Jan 2005
    West Subs,Melbourne
    The only defectable info about gauges i can find is.. for External Gauges
    http://www.vicroads.vic.gov.au/vrpdf/rdsafe/VSI%208.pdf
    Does anybody have any info on installing the gauge?
  1. gauge installation
    By Snotty in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-06-2010, 01:24 PM
  2. vl temp gauge
    By frankyj54 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-09-2006, 11:22 PM
  3. temp gauge
    By rusty_ben in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-03-2006, 12:38 AM
  4. Temp gauge or fan?
    By The1985divo in forum General
    Last Post: 08-08-2005, 10:18 AM
  5. temp gauge
    By mag in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-08-2005, 09:54 PM
