Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Thread: what's the difference between the v6 and v8 auto boxes?
    vn berlina s1 5.0L
    Jan 2005
    Default what's the difference between the v6 and v8 auto boxes?
    hey guys. my vn v8's got a flogged box and i've just been given a v6 box with a damaged housing. I'm wondering what the difference between the v6 and the v8 th700 is.
    what i'm thinking is use my v8 bell housing and torque converter and stuff and use the back end, all the gears and clutches and stuff, out of the v6 box. does that sounds possible? if it is, it means i wont have to fork out for a new box :-)
    thanks,
    stu
    J_D
    J_D is offline
    VN S1 and VS V8 Statesman
    Jul 2006
    Ipswich. QLD
    Well the owners handbook says they both have the same ratios but the refill oil capacity is 4.8 for V6 and 5.0 for V8 so my guess is the V8 has a larger torque converter maybe?
    Im not a complete idiot, some parts are still on backorder!
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    From memory the imput shafts are different on the V8 and V6 boxes. Yes the extra fluid capacity is made up in the TC.
    AirStrike
    Selling FG G6E Turbo and buying a N/A Supra
    vn berlina s1 5.0L
    Jan 2005
    Quote Originally Posted by AirStrike View Post
    AirStrike
    input shaft being between the torque converter and engine crank? well, flywheel...?
    car
    Jul 2006
    greensy, melb
    my theory was when mine blew if it did it once it'll happen again so when i went hunting for a new 1 i got quoted around 2k from a few place4s for a new 1 or $1500 for a rebuilt with stage 2 shift kit so i got the shift kit and never looked back cos the box feels rock solid now and it shifts ten times better
    "A life lived in fear is a life half lived"
    J_D
    J_D is offline
    Jul 2006
    Ipswich. QLD
    the input shaft is between the torque converter and the box.
    Aug 2004
    Jolly Wreckers in Dandenong sells them for $130, I found recently rebuilt one only done 8,000 kms since rebuilt (saw a sticker on drivers door frame) so grabbed it and man, it is so clean inside and out!!, now its in my garage. If you're lucky you can find them in good wreckers.
    AP
    vn berlina s1 5.0L
    Jan 2005
    Quote Originally Posted by AlpineRaven View Post
    AP
    a v8 box for $130?
    i want one!
    VN Commodore
    Feb 2006
    if ya can get a v8 auto for that price i would be buying as many as ya could. ya can get good monye for them even if they need a rebuild.
    Aug 2004
    Thought V8 transmissions were the same as V6 transmission, only that torque converter was different?
    If it was an V8 there, I'll be first person to take it out!
    AP
    Aug 2004
    they are pretty simular the v8 has a different convertor larger also i think th input shaft is slightly different and the bell houseing is a different design
    VP Executive R-spec
    Jan 2005
    The V8 one will be the chev bolt pattern so they should be the same as the ones on the small blocks in the states. Maybe some import place brings them in for cheap?
    vn berlina s1 5.0L
    Jan 2005
    Quote Originally Posted by greenfoam View Post
    i had a bit of a look, there's T700's all over in the states, but the cost to ship them international makes it not really worth it. maybe if you wanted to buy a whole shipping container full it would be worth it. there seems to be a market for them...
    so torque converter, input shaft...? that i can deal with. i was more worried about the clutch/bands arrangement being different
    Aug 2004
  15. #15
    dans_vz's Avatar
    dans_vz is offline formerly vp_berlina
    05 VZ V6 Exec & 92 VP Calais SII V8 Manual
    Aug 2006
    Albury/Wodonga
  16. #16
    JSTPOZN's Avatar
    JSTPOZN is offline S.A. The Defect State
    Air Bagged VR Calais, VLCT RB20, VLCT EFI V8 Turbo
    Dec 2005
    SA, North
    Why the hell would you bother?
    If Your In S.A (Adelaide) And Have VR/S Parts & VL Parts For Sale
    Go Here --->
    http://forums.justcommodores.com.au/...tml#post683835
  17. #17
    dans_vz's Avatar
    Aug 2006
    Albury/Wodonga
    well if your v6 auto trans buggers up and you are able to obtain a v8 one for example
  18. #18
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    fair question - I'm also wondering this, looking at a transmission change further down the track. Will a V8 transmission fit? What else could I stick in? I'd really like to get a 6 speed manual into mine eventually - can anyone tell me (in a nutshell) what's involved?
  19. #19
    VP Executive R-spec
    Jan 2005
    I happened to be on the CRS website today and noted that they do a converter "AP 52 Holden V6 T700 auto to Holden V8 & Chev "
    So there you go, buy it once and get cheap gearboxes for a looooooooong time
    Also seems you can go the other way around "AP 112 V6 Holden to Chev Auto (T350/T400/T700/Powerglide)"
  20. #20
    pandaman's Avatar
    pandaman is offline Aussie Muscle Fan
    VN Berlina 5.0 A4
    Feb 2006
    I happened to be on the CRS websote today and noted that they do a converter "AP 52 Holden V6 T700 auto to Holden V8 & Chev "
    hahaha, whats the bet that adaptor plate will cost more than a V8 box? If my drunken and cynical mind is wrong then that's a damned good find though!
    Beau Duke: Man, I'm never gonna get outta this car again. I'm gonna live in it, I'm gonna eat in it and I'm gonna make sweet love to it!
    Luke Duke: You mean you're gonna make sweet love IN it.
    Beau Duke: Oh no, I'm gonna have sex with it.
  21. #21
    VP Executive R-spec
    Jan 2005
    Yeah no doubt it would be a couple/3 hundred but it should last you forever!
  22. #22
    pandaman's Avatar
    VN Berlina 5.0 A4
    Feb 2006
    Quote Originally Posted by savage1987 View Post
    For a 6 speed, it depends on which box you go for. Assuming you go for a T56, there are a few options.
    1. Hunt down a genuine bellhousing and clutch setup from a manual vr/vs/vt s1 gts(senator as well I think), get the front half of the tailshaft too. Find a T56, any T56, stuff around installing the mofo.
    2. Get a bellhousing from CRS or dellow. Find a T56 box and a suitable clutch, stuff around installing the mofo, and get the front half of your tailshaft modded to suit. Likely to work out slightly cheaper than hunting down genuine parts but will probably involve more work.
    3. Get a mal wood kit - expensive but comprehensive. Apparently an absolute pleasure to fit as well, but they will only supply the full kit, not parts of it.
    These are a gross oversimplification, but that's the basics anyway. Oh yeah, forgot the pedal box and centre console. Those all need to change of course. And if you're runnning the holden ratio set, it'll need some shorter diff gears, 100km/h in sixth gear with standard VN diff ratio would be under 1300RPM, not so cool.
  23. #23
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    check the vin tag on a v6 against a v8
    for my money they are the same just use your bell housing
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
  24. #24
    VN Commodore
    Feb 2006
    if the auto are the same i reckon that is pretty funny. i sold a v8 one for 700 or something. but surely they couldn't be.
    don't the auto's have different numbers on the side
  25. #25
    pandaman's Avatar
    VN Berlina 5.0 A4
    Feb 2006
    Actually, I'm pretty sure that the only differences are the bigger torque convertor on the 8 and the bellhousings. Big problem is that on the V6 box, the bellhousing is part of the case casting. Take a look at the photo at the bottom of this ebay link:
    http://cgi.ebay.com.au/Commodore-V6-...QQcmdZViewItem
  1. Help with 6x9 Boxes!!
    By SKNOT9 in forum Car Audio
    Last Post: 21-03-2007, 10:27 PM
  2. VT & VX auto transmission, any difference?
    By accentstencil in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-07-2006, 01:39 PM
  3. difference between s1 auto and s1 manual
    By VN-88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-02-2006, 07:47 AM
  4. VT Air Boxes.
    By VTSSDUDE in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-12-2005, 10:03 AM
  5. Sub Boxes
    By Troy711 in forum Car Audio
    Last Post: 22-03-2004, 11:19 AM
