Results 1 to 5 of 5
Thread: V8 FE2 front sway bar part number and V6 springs
    VP Executive R-spec
    Jan 2005
    Default V8 FE2 front sway bar part number and V6 springs
    Been replacing the main sway bar rubbers today and found that I could still read the part number on the front bar, so if you v6 guys are looking for a big sway bar at the wreckers find this one.
    Part number 92?0?41501 (V8 FE2 front sway bar)(not 100% on the 0 as that number is damaged but all the part numbers seem to be 920.....something so you can be 99% sure.
    Also someone wanted these a couple weeks ago
    Part number 92023752 (V6 FE2 front springs)
    I'll also post this in the part numbers section in case Airstrike has issues
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    VP Executive R-spec
    Jan 2005
    Unsure man, but it's a couple/few mm bigger because the rubbers are a different size and part number too
    93 VP Berlina Series II
    May 2006
    hey can anyone help me with the option code on the compliance plate to check if mine already has FE2? It's not something obvious.. like "FE2" is it?
    I've never checked, but it has pretty tidy handling, I'm surprised.
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    92023752 - Springs Front V6 P.O. FE2
    As for the sway bar there is 4 different part numbers but none for the sedan to show there is a difference between the V6 and V8.
    I have no issues foam
    AirStrike
    Selling FG G6E Turbo and buying a N/A Supra
  1. CAI part number
    By vsMick in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-09-2007, 11:45 PM
  2. Part number??
    By Bubbles in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-03-2007, 06:50 PM
  3. Sway Bar link kit, part numbers changed
    By greenfoam in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-01-2006, 02:58 PM
  4. part number
    By Troy711 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 20-12-2005, 09:23 PM
  5. Part Number VS Calais Front passenger door mechanism
    By Wallyx3 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-08-2005, 10:57 PM
