Been replacing the main sway bar rubbers today and found that I could still read the part number on the front bar, so if you v6 guys are looking for a big sway bar at the wreckers find this one.
Part number 92?0?41501 (V8 FE2 front sway bar)(not 100% on the 0 as that number is damaged but all the part numbers seem to be 920.....something so you can be 99% sure.
Also someone wanted these a couple weeks ago
Part number 92023752 (V6 FE2 front springs)
I'll also post this in the part numbers section in case Airstrike has issues![]()
