Results 1 to 5 of 5
Thread: idle issues, 500rpm constant, thoughts????
    missus (in more ways than one)
    Sep 2005
    Default idle issues, 500rpm constant, thoughts????
    hello,
    i had to change my IAC vlave cause it would drop down to 500 itermititaly and then somtimes stall, so i got one off a know working throttle body, put it on, (cleaned and fresh) then i reset the comp, but now it contantly idles at 500rpm in gear and about 550-600 in p/n.
    i know it would hvae somthing to do with the pintle but i thought these self adjusted. i also adjust the TB stop screw cause the butterfly was sticking but not too much just enough so it doesnt stick. the TB is a v8 item polished out. all the screws and bolts are tight and all hoses are on
    anybody?
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    How long did you disconnect the battery for? sounds like it hasn't actualy reset properly. i'd try resetting it again. make sure the engine is up to running temp so there is no extra fuel going in and all the accesories are switched of so there is no extra load on the engine
    edit. what are you judging the idle speed by, if your using the car tacho i'd suggest that it's probably not very accurate. i've had the same battle for a year with my car cause i thought it idle'd at 1000rpm, i ignore the tacho now, it only goes 4900rpm as i hit the rev limiter. go figure? the only way to check the idle speed correctly is probably with an ADLD cable or diagnostic tacho which has a known calibration
    Body by Holden, Soul by Brock
    the Legend will live forever
    Calais3800's Avatar
    Calais3800 is offline KALAIS_KRAZY
    VN Calais v6
    Apr 2006
    Frankston district
    Quote Originally Posted by CSL View Post
    no they do not self adjust, on the V6 u have to take em out give em a dammed good clean wiff TB cleaner an reset it to 28mm......... i also blasted off all the buildup inside where u cant really see with a air gun. i would say this is the cause off your idle problem. i hope this helps, good luck.
    Sep 2005
    thanks guys, i am using a 4 digit dgital tacho w/shift light from a reputable company but you can feel it about to stall.
    i take it thats 28mm from the end of the plastic to the top of the pintle,, i'll do that and give it a good reseting, cheers guys
    Sep 2005
    tis all good just adjusted the pintle to less than 28mm measures fvrom the flange
    thanks guys
  1. VS S2 drivetrain into S1 - any issues / thoughts
    By specter in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-11-2006, 04:02 PM
  2. VR needs constant revival :(
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-11-2006, 12:34 PM
  3. idle issues
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-08-2006, 09:48 PM
  4. Please help -VN idle issues
    By Norco in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-07-2006, 02:50 PM
  5. VS idle in reverse issues
    By squidda in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-06-2006, 09:27 PM
