Results 1 to 8 of 8
Thread: Vr/vs Dash And Instruments In A Vn
    vn s-pac v6 series-2, vp v6, vr berlina v6
    Sep 2004
    Cool Vr/vs Dash And Instruments In A Vn
    i know a lot of this is covered in other post's but this kinda combines it all.
    what i have is a commodore vn s
    i have a lv2 instrument cluster.
    what i want to do and to get some idea of it being possible or not before i go buying parts is....
    can i place a VR/VS dash in my car like someon else already asked but at the same time swapping my instruments for the matching VR/VS lv3 instruments and have my wipes/lights/ ect all hooked upto the new VR/VS switches without getting my electrics modded too much? and would the digital stuff (in fact everything) on the VR/VS LV3 instruments work once hooked up seeing as though my car only has a LV2 instrument cluster? i expect if extra wires need to be connected that they will be under the dash somewhere already just not connected as i have a bunch of wires that sit right under my dash/steering wheel that just sit there not connected to anything.
    anyway any ideas of this working or not would be great. i want to have the vr/vs dash as it look a lot better but with all the wipte/light ect switches working as they should without too much trouble and a LV3 insterument cluster with everything working on it without getting a whole lot of new wiring or such.
    cheers. and justcommodores rulez.
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    It could be done mate but it come down to your skills or how deep your pockets are!! Basically the wiring looms wont match up, so you would have to splice the VR/VS loom into your current one.
    Selling FG G6E Turbo and buying a N/A Supra
    Sep 2004
    Default thanx
    thanx mate. well skills,time and patience is no problem. money is ok for getting the dash and the instruments. if its a case of splicing the wires into mine then thats a simple if i can get my hands on a wiring chart/digram/colors. just not sure if the LV3 instruments with the digital stuff would ALL work put into mine and connected to my current wiring as i currently have a LV2 instrument cluster. or if i would need to have extra wiring put in.
    HSV VX Clubsport.
    Sep 2004
    Wyndham, Western Australia
    Good to see we think alike.. Ive have also been thinking about fitting a VR/VS dash into my VN.. Ergh i hate that VN Dash/Instruments. and after a few 's i realised it was time for a change and that it could be possible..
    I just have to consider the time it will take to rip the old dash out and fit the new one & ALSO i cant figure out how to get it out of the damn car! ive re-trimmed the interior and found it difficult to get the dash out for a new coat of paint. (ended up covering everything in newspaper and spraying the bugger while it was still in there)
    So let us know how you go, im interested to hear more.
    MSN: dangerman3000@hotmail.com
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    In short it is possible but you need to splice in about 12 wires into your existing loom for an additional connector (called no4 connector),run another wire across the dash to pick up a output from your ecm connector and change the position of a few lugs in your original instrument connectors.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    Nov 2003
    I have done this a few times now. The last time I did it, I thought about using the BCM and loom as the splicing shits ya. Then getting the wipers to work right also shits ya, that using the BCM from the donor car would be easier (maybe).
    It may have other headaches with it using the BCM, but its worth a try as the PRO & CONS might actually make it easier then splicing into different places.
    Nov 2003
    Quote Originally Posted by StealthX
    Take the vents off, undo the exposed nut/bolts. The same goes for the plastic near the windscreen. The VN may have 3 bolts along the front of yours or one, I have heard of people having just one there, but yeah undo your bolt along there. The fuse area has to be undone and the centre console area. If you removed your seats first, you should be able to walk the dash str8 out of the car.
    The donor car is the same but it hasnt the attachment points in the same spot that the vents on the VN cover up. The donor cars are near in the same spot apart from that one little attachment point difference.
    If you have the patience I would also use the wiring loom, or atleast its plug setup in the conversion. The VR and ups looms, break apart at the dash, unlike my vn's whos looms are all one and you have to first cut the cable ties holding the loom to the dash, before you can fully remove it, where as with a VR + it has 2 plugs down on the right hand side, that allows you to remove the dash with out having to cut the ties on the back holding the loom to the dash.
    VZ SV6
    Jun 2004
    Default Work = Cost = Good Looken
    Sounds like alot of work, but the only thing that i dont like about my car is how the dash sticks out like a saw thumb, how much do you reckon this sort of thing would cost?...
  1. VR/VS instruments into VN
    By hemi01 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2007, 12:36 PM
  2. instruments
    By lurkin308 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-12-2006, 10:11 AM
  3. cant see the instruments sometimes
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 11-12-2005, 11:05 AM
  4. Replies: 2
    Last Post: 02-11-2005, 07:10 AM
  5. VX or VS instruments in a VH
    By Lemonhead in forum Electrical Wiring / Questions
    Last Post: 15-06-2005, 04:07 PM
