Results 1 to 9 of 9
Thread: quick question about switching from gas to petrol
    JD
    JD is offline Donating Member
    VS Berlina
    Aug 2006
    Deep South, SA
    Default quick question about switching from gas to petrol
    ok this has happened a couple of times.
    when i swich from gas to petrol and drive after it swiches fully and i wait about a minute and then drive it will lack power, use more fuel ( does for about 15mins ) and the check engine light will come on for about 30secs.
    but if i wait about 3 mins before driving off it will run fine and no engine light.
    and it doesn't do it at all when i swich from petrol to gas even if i drive immeditley after swiching.
    not too phased really just wondering why it does it on petrol and not on gas
    We got rep back, yaaay!
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    Check and see what error code the warning light responds to. See what is playing up. There's enough threads on here about how to read the codes, post it (them) up and we'll tell you what it means.
    Gravity is proof that nature keeps getting us down.
    VP Exec
    Jun 2005
    One explanation is that the ECM is learning the fuel mixtures on LPG, resetting the block learn values, and then running badly when operating in open loop ie. O2 sensor cold, open loop idle, using those values until it can operate in closed loop and relearn the appropriate values on petrol.
    JD
    VS Berlina
    Aug 2006
    Deep South, SA
    Quote Originally Posted by Cheap6 View Post
    well thats what i was kinda thinking but it doesn't explain why it does it only swiching back to petrol. and not switching from petrol to gas.
    might just let it idle and adjust al the time.
    FXST01's Avatar
    FXST01 is offline The Grey Man
    VP V6 Auto Sedan
    Jun 2005
    El-Arish-Shamal-Sina-Egypt
    I got a feeling its running on both gas and petrol until all the gas has been expended from the gas line. Does the gas get fed through the throttle body and not the injectors, if so then maybe vacuum is helping it to draw off the gas.
    When switching to gas from petrol, its immediately cutting the petrol off at the injectors.
    My 2c
    Illegitimi Non Carborundum
    VP Exec
    Jun 2005
    Quote Originally Posted by JDZVNHSV View Post
    It would because the ECM is not controlling the fuel on gas but FXST01 your suggestion sounds reasonable.
    JD
    VS Berlina
    Aug 2006
    Deep South, SA
    Quote Originally Posted by FXST01 View Post
    My 2c
    i'd agree with that, im getting the throttle body cleaned on the weekend so hopefully it will switch over a bit better.
    vn s
    Sep 2006
    i had the same problem and took it to a auto gas place and got it tuned for 30 bucks, although it still did it it wasnt as bad and i was told the explanation for it was there is still gas in the lines.
    JD
    VS Berlina
    Aug 2006
    Deep South, SA
    Quote Originally Posted by adams vn View Post
    its not going to stuff anything up, still having gas in the lines is it?
  1. Switching from Gas to Petrol problem
    By taylorb100 in forum Electrical Wiring / Questions
    Last Post: 27-08-2009, 04:16 PM
  2. Quick Question
    By vt_ss_5l in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-12-2007, 12:13 PM
  3. quick question...
    By jolly_97 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-08-2006, 09:20 PM
  4. A quick question
    By evil_vr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-05-2006, 12:33 AM
  5. Quick Question: VT SS RIMS = Quick Answer please
    By Henerz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-03-2006, 06:33 PM
