Results 1 to 3 of 3
Thread: VN compressor bearing
    VY Berlina
    May 2005
    Default VN compressor bearing
    I'm pretty sure the bearing in my A/C pulley/clutch unit is stuffed.
    With A/C on everything sounds good
    With A/C off it makes a horrible whining sounds
    Is it possible to take the pulley unit off? Should I take this one to the professionals?
    Paddy
    VY Berlina
    May 2005
    Ok got a quote today for $160. This is for, taking off compressor, replacing bearing and re-gassing system.
    Is that reasonable? Apparently you need to use a pulling tool to remove the hub so the compressor has to be taken out.
    Paddy
    308 VK Calais, VK EFI Berlina, V6 VN & Kenworth...
    Nov 2005
    Adelaide(City of Godbothers)Churches S.A.
    You may find it's not your A/C unit but worn brushes in your Alt.Her Berlina did the same thing & I 2 thought it was the Comp.$2 for sum new brushes shut it up...
    Tony 308vkcalais:
  1. How to replace the air compressor pully bearing
    By hemi01 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-10-2007, 08:23 AM
  2. WTB - VT 5L A/C Compressor
    By STEALTHY™ in forum Swap / Wanted to Buy / Trade
    Last Post: 04-01-2007, 10:04 AM
  3. vt Compressor
    By fatduck84 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-12-2006, 08:09 PM
  4. How Much: VP air con compressor?
    By sparra_gump in forum Swap / Wanted to Buy / Trade
    Last Post: 24-02-2006, 10:57 AM
  5. Air Con Compressor
    By brad_m_is in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-09-2005, 06:26 PM
