Had a mate have a look at my coil pack on a vn v6. decided he would pull off the wires connecting the coils to the ignition module. Does anyone have a diagram or an idea of where these wires are to be re connected. There are three dark blue all together,then a single blue a yellow and a green. thanks.
here is your solution take the coil place it in front of youwith the single bolt away from you and the other two towards you these are the bolts you bolt the coil to the engineplate to ok the three blue wires that are conected together are on your left on your right the single blue is on your right at the far terminal the single green is in the middle and the yellow wire is closest to you if you have done this right the coil top will be on your left and the coil base will be on the right with the conection plug hole faceing you hope this helps i you are still stuffing around with a series 1vn coil later on getyour self a vp vr coil they will definetly work better
i think the gregories has a picture of the coilpack split from the dfi module and the wiring etc
Body by Holden, Soul by Brock
the Legend will live forever
probably shouldnt let your mates de-wire your coilpack in future ..
never late in a 3 0 .. uhhh ... intercooled turbo
yes i drive an mx6 turbo ... its probably quicker than yours.
Funny how its always the "mate" who did it.
