hey guys i just bought a SC 14 supercharger off a mater 400 bucks with everything needed besides a couple of hoses... anyway it won't be going on untill late novmber early december so i can save up some funds for a few more mods to go with it.
It is going on to a series to vp in a vp commodore with 153,000 k's on the clock.
i will be running it with the 3 psi pulley, i'm going to get pacemaker extractors and a better zorst for it. probably look into heatshielding the intake pipes and pipe from air box tothe blower
What size exhaust would be recommended? any other things that i should change such as injectors, fuel pump, ignition, leads, plugs etc?
busted ass vp
3 '' exhaust is always best with superchargers/turbos.
You will need longer leads to relocate your coil pack. No need for larger injectors unless you are upgrading the pulley to higher psi then you will need a few other mods to get it goin. Mine runs fine on 3 psi , I have a 3'' and it used to sound a bit too loud now the chargers on its nice...!
only good cops a dead cop...
s1 vn commodore turbo
t3/t4 front mounted turbo
Intercooler ---3"exhaust
stage 2 shift kit---B&M Qicksilver shifter
3:45 lsd
18" Cv8z Monaro rims 245's
your refering to silicon piping, you can buy it at auto bahn for like 1/5m for $30 then you need clamps, are you running a BOV?
thanks guys, it came with the longer leads required for relocation of the coils packs, that silicone pipping is what i was thinking of, wasnt sure if it was suitable tho. and it came with a bov which i am using.
For now i'm going to run 3 psi then see how my motor holds up. Few months down the track i'll try sourcing a smaller pulley to run maybe 5 or 6 psi.
Where would i be able to track down a pulley for 5 or 6 psi? what size does it need to be.
If i was to run 5 psi what things would i have to change?
busted ass vp
answers anyone? i know i've got a while but i wanna get it sorted now so i can set a target to save up for.
thanks
busted ass vp
do a search dude! this info should be thoroughly covered somewhere in these forums....
in short, you can get the smaller pulleys from Castlemaine Rod Shop (CRS), for I think $300 for the whole pulley kit? I dunno if you'll need a shorter belt or not tho.....
you will need more fuel with 5-6psi, so either a rising rate fuel pressure reg, or a set of bigger injectors and a tune.
