Page 1 of 2 12 LastLast
Results 1 to 25 of 49
Thread: Best Injector Replacement for a VN
    Sep 2006
    Default Best Injector Replacement for a VN
    I'm doing some work on my sons VN Calias and have found one of the injectors are stuffed so I'm going to get a set of Reco Injectors, what model injectors would be the best.
    VN,VR or VS
    are they a direct swap or whould I run into problems
    xcop5l's Avatar
    xcop5l is offline 4th year spanner spinner
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    there a basic swap but use silicone spray or similar on the o rings coz they can grab and tear then youve got a leak
    Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
    MY RIDES
    [SIGPIC][/SIGPIC]
    http://forums.justcommodores.com.au/...ad.php?t=41837
    Sep 2006
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    what i understand there all the same
    maby the eco tec ones are differnt
    MY RIDES
    [SIGPIC][/SIGPIC]
    Sep 2006
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Yeah all the same flow rates etc... Go VT ones if you can man, from what i've heard they are the pick
    vt exective
    Oct 2006
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Quote Originally Posted by glowworm View Post
    vn to vs are all the same VT are not they are different ..glow
    Define Differnt?
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by Mack View Post
    Define Differnt?
    Im pretty certain they have a higher flow rate than VN to VS.
    FXST01's Avatar
    FXST01 is offline The Grey Man
    VP V6 Auto Sedan
    Jun 2005
    El-Arish-Shamal-Sina-Egypt
    VN series 1, 8-88 to 10-90 uses injector number 0280-150-901 which flows 146.3 GPM @ 3 BAR. Resistance 14.5 Ω.
    VN series 2, 11-90 to 10-91 uses injector number 028-0150-960 which flows 150.5 GPM @ 3 BAR. Resistance 14.5 Ω.
    These injectors are also fitted in the
    VG UTE 11-90 to 10-91, VP COMMODORE 11-91 to 07-93 and the VR COMMODORE 06-93 to 04-95.
    VT - VY N/A, 09-97 to 06-03, uses injector number 0280-155-777 which flows 150 GPM @ 3.5 BAR. Resistance 12 Ω.
    The VN - VR injectors are what is classed as an EV-1 injector pintle type which are open to problems when used at an incorrect fuel pressure, hosing is a problem if pressure is too low or too high and the pattern can also be forced too wide for the target area if pressure is too high.
    VT - VY injectors are what is classed as an EV-6 injector which uses a multi orifice director plate style technology to better atomise fuel across various operating pressures. These injectors allow more flexibility in relation to operating pressures without compromising spray efficiency or fuel atomisation.
    Illegitimi Non Carborundum
    1991_Vn2nV's Avatar
    Mar 2006
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Had my regulator replaced today, my fuel pressure was 80PSI instead of the reommended 40PSI.
    Sep 2006
    Well injectors have been replaced with VR injectors, Fuel rail was full of crap cleaned it out and put in the reco injectors, car is running 100% better, thanks for the help guys.
    J_D
    J_D is offline
    VN S1 and VS V8 Statesman
    Jul 2006
    Ipswich. QLD
    So do VT injectors fit or not, because they sound like a better option if you can make them work. I would do this mod if it wasnt difficult.
    Im not a complete idiot, some parts are still on backorder!
  15. #15
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
  16. #16
    J_D
    J_D is offline
    Jul 2006
    Ipswich. QLD
    I might have to go to the wreckers and check that one out. Should get more power and better economy from VT injectors.
  17. #17
    VP Executive R-spec
    Jan 2005
    Make you you change the regulator too then, the post up there^ says they need 3.5 bar to reach the same flow as a VN injector
  18. #18
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    I got some new Bosch ones about 12 months ago good shit they are. Under $300 great price too.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
  19. #19
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    you can run carbly cleaner thru the injectors, it helped mine a fair bit pulse them with a battery, FXST01 nice post very useful
  20. #20
    FXST01's Avatar
    VP V6 Auto Sedan
    Jun 2005
    Just bought a set of VT injectors off ebay and should have them in this weekend in a V6 VP. Best i charge up the camera me thinks, i feel a "How To" coming.
  21. #21
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    Quote Originally Posted by greenfoam View Post
    hey greenfoam, would that be needed on a VS?...i guess what im asking is how many bar does a vs normally run at?
  22. #22
    J_D
    J_D is offline
    Jul 2006
    Ipswich. QLD
    I wouldnt think you would have to change the pressure regulator as the VNs1 injector flows 146.3 GPM @ 3 BAR. Assuming a worst case scenario of flow rate falling at the same rate as pressure (which it doesnt) the VT injector would still flow 128.5 GPM @ 3 BAR. Flow increases about 1/5th for each doubling of pressure so the flow difference would be insignificant, about a 6 GPM decrease for a .5 BAR pressure drop.
  23. #23
    VN Commodore
    Feb 2006
    if vt injectors are rated lower. why put them in. i am a little comfused on this one..
  24. #24
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    I had my injectors running at 5.333 Bar, lol. My regulator was stuffed, Would having twice the fuel pressure wreck my injectors?
  25. #25
    J_D
    J_D is offline
    Jul 2006
    Ipswich. QLD
    Quote Originally Posted by defa View Post
    Because they are a different design that has a finer spray pattern, thus vaporising the fuel better. Should provide better fuel economy and performance.
    EDIT: And if the VT injectors can supply the correct amount of fuel to a VT engine then they can supply the correct amount of fuel to a VN engine as they are the same size engine.
  1. Injector Job
    By VNSSMAN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-12-2006, 09:57 AM
  2. Injector help....!
    By ruredi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-10-2006, 02:04 PM
  3. Injector help please!
    By Shortstuff in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-08-2006, 06:30 PM
  4. Injector question
    By down_with_the_system in forum General
    Last Post: 07-03-2006, 05:53 PM
  5. Injector info
    By Lawso in forum V6 Development And Modification
    Last Post: 27-07-2005, 08:43 PM
