Results 1 to 13 of 13
Thread: tail lights turning off when brake applied!?!?!?!?!?
    VN Executive V6
    Sep 2006
    Liverpool, Sydney
    Default tail lights turning off when brake applied!?!?!?!?!?
    hey guys, i am ahving problems with my rear, drivers side brake lights. i turn on the lights, all four lights turn on, but as soon as i apply the brake, on the drivers side, the bottom light will turn off. how do i fix this problem, if i open up the boot and jiggle the socket around, the light will come back on, when the brake is applied, but after a bit of driving, it turns itself back off again, is there a fix to this problem? cheers
    Al3x
    Mines just faster cos its Red
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    yep, you gotta find the loose wire causing a short circuit.
    Body by Holden, Soul by Brock
    the Legend will live forever
    Shortstuff's Avatar
    Shortstuff is offline Random
    1995 VR II V6 Wagon
    May 2006
    Or it could be a faulty globe. My lights used to do that and they were fine once I replaced the globes.
    WAGON MAN's Avatar
    WAGON MAN is offline Gas Sleeper
    VX S2 Berlina Wagon with Phreddied bits.
    Jun 2006
    North Coast , NSW
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Yeah sounds like globe to me 2, the 2 taillights run off the same circuit, so if it were wiring both lights would go out.
    VP Exec
    Jun 2005
    Could be bad earth. Most likely tailight socke t on that side is corroded due to water entry into the tail light. New sockets and harness will be the permanent fix. And fixing the water leak, usually the lamp assembly itself.
    Bax
    Nothing
    Jan 2004
    QLD
    two taillights run off the same circuit but when he wiggles the connection at the bulb it drops out.
    its either the bulb or the connections with the wiring. my guess would be the wiring @ the connection to the bulb- change the bulb with the other one if you want to check that.
    VN Executive V6
    Sep 2006
    Liverpool, Sydney
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    they're wires in series = 1 globe out means both out,
    mines playing funny buggers atm
    Benji's Avatar
    Benji is offline Vote For Pedro
    Looking For A VR - VS Stato V8
    Aug 2005
    Central Coast
    People i had this problem fixed acouple of weeks ago its a bad earth in the socket cost you about $15 buks to fix its from corrostion and shit thats why when you wiggle it it starts earthing again and working dont try and dodgy it up it doesn't work lol
    Trust me thats what i would be fixing
    Cheers Benji
    [SIGPIC][/SIGPIC]
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Quote Originally Posted by PaRaDoX616 View Post
    They're wired parallel not series, so if one globe goes the other still works
    Apr 2006
    Auckland NZ
    Quote Originally Posted by vn6pwr View Post
    correct. and the corrosion thing is a common problem with the actual lamp assembly leaking. there is some sort of compound that you can get (holden used it in the later model cars to stop corrosion) grease like but pale yellow/cream in colour but seems to work as it's in my VS rear globe sockets and i've never had any trouble with it
  1. [SA] Vs Tail lights & Tinted Vp rear tail lights and garnish
    By hothousevn in forum Parts And Other Items For Sale
    Last Post: 23-10-2007, 01:46 AM
  2. lights not turning themselves off
    By Ristof in forum VY Holden Commodore (2002 - 2004)
    Last Post: 12-06-2006, 04:05 PM
  3. turning you dash lights down. what the?
    By vnbelina in forum General
    Last Post: 13-04-2006, 10:38 AM
  4. park lights come on when brakes applied help
    By 94 VR BT-1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-03-2005, 04:46 PM
  5. Tail/brake Lights Warning Lamp
    By Frederick in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-01-2004, 07:19 PM
