hey guys. my aircon isnt coming out of the vents on the dash and the back of the centre console. but is coming out of the feet vents. i have checked that they are open and so i took the side and middle vents. and the centre console. i ahve no idea what is wrong. i know nothing about aircon. ponly that it will cool me down.
thanks for any help you can give me.
cheers
matt
p.s(91 s2 vn)
YOU KNOW WHAT THEY SAY.......WAIT......NO I DONT
before u start ripping anyhting out, check that the VAC lines are all right
it's in the engine bay, from the air box area, you'll see a black tube
one end runs under the car and into a big ball (VAC tank) and the other end runs to the throttle and branches to throttle and into the car
i had the same prob (blows to feet) and i took the entire dash apart. wasn't the problem, but it totally screwed me up
so beware!
i looked there and i think i saw those things u were pointing 2. but they were intact. any other ideas?????
Ye, Nick is right, i would bet its vacumm. Im pretty sure the VN has a vacumm operated switch, you know the level switch, it operates a vacumm switch in the back and then feeds vacumm to the different suction doovers lol.
I had to replace that little part on the switch that all the vac lines go onto.
But hell it could be a few things behind there. one word of warning but, if you do it yourself and try to fix it, make sure the vac lines go on exactly the same place as it can be a real pain getting it all working properly again
thanks guys. ill at least have a go at looking at the problem. after that i got no idea..
cheers
matt
hey mate, i had the same problem, read this, i didnt explain it very clear but thats what my problem was and it worked for me, i dont know if the guy had the same prob because i wasnt told but the exact same thing happened to me
Air Con Probs ( i think)
also check that u have a vacuum ball
its in the front of ur left ( or right looking from the front) wheel
i lost mine and thats the cause of my problems
