+ Reply to Thread
Results 1 to 14 of 14
Thread: Horn not working.
    cohn's Avatar
    cohn is offline VN28CN cohn Executive
    VN Calais Turbo
    Nov 2004
    Penrith
    Angry Horn not working.
    I have a VN s1 with an aftermarket steering wheel and an autotenica boss kit. when the wheel is turned from 9 o clock to 3 o clock the horn doesnt work but from 3 to 9 o clock it works fine?
    when the wheel is turned anticlock wise it will work from 9-12 o'clock position. but when it is turned clock wise it will only work from 3-9 o'clock posistion.
    has anyone had this problem before and know how to fix it as i need to, so i can pass rta stuff.
    I have tried cleaning the contact poits on the boss kit and stuff, even woth sand paper, it doesn't make any difference.
    Any information would be much appreciated.
    Thgankyou.
    Colin.
    Soon to be back on the road, Turbo VG.
    dans_vz's Avatar
    dans_vz is offline formerly vp_berlina dans_vz Executive
    05 VZ V6 Exec & 92 VP Calais SII V8 Manual
    Aug 2006
    Albury/Wodonga
    could it be wires or contacts points not linking up properly when you turn the wheel?
    xcop5l's Avatar
    xcop5l is offline 4th year spanner spinner xcop5l Executive
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    id say get a new one fit it and if it still dosnt work take the new one bac and look deeper.
    Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
    MY RIDES
    [SIGPIC][/SIGPIC]
    http://forums.justcommodores.com.au/...ad.php?t=41837
    VN S2 Berlina Wagon
    Apr 2004
    VN Caladore
    Aug 2006
    I had problems with mine last night and fixed it today. It was the strangest thing.. The horn wouldnt work but when I turned the wheel to the right it would sound...
    So I took it off and checked to see if any of the wires were pinched under the boss, but all was fine.. It turned out that the wire had come loose from the crimped connection, and although it was still crimped, it was no longer in the metal... Put a new connector on it, and fixed...
    Hope yours is something simple like that ...
    I spend too much money on my cars & bike
    Click me to see my ride
    VN Caladore
    Aug 2006
    OK ... Now I have jinxed myself... Fixed the problem ... Worked fine last night, tested it this morning in the garage ... Drove out got down the road and stopped again ... Connection was fine this time ... So I got no idea... Can't find what fuse the horn runs off on the fuse box tho ... It is not listed .. Any know... It is a sires 2 VN...
    bike :P
    May 2006
    step 1: wind down window
    step 2: scream obscenity of your choice
    step 3: wind up window
    Problem solved!
    pandaman's Avatar
    pandaman is offline Aussie Muscle Fan pandaman Caprice
    VN Berlina 5.0 A4
    Feb 2006
    99% of horn problems are earth related, sounds like as you turn the wheel the earth loses contact at some positions, solution would be to pull it apart and make sure the earth wire is constantly in contact at all wheel positions.
    Beau Duke: Man, I'm never gonna get outta this car again. I'm gonna live in it, I'm gonna eat in it and I'm gonna make sweet love to it!
    Luke Duke: You mean you're gonna make sweet love IN it.
    Beau Duke: Oh no, I'm gonna have sex with it.
    pandaman's Avatar
    VN Berlina 5.0 A4
    Feb 2006
    Quote Originally Posted by VP_commo_driver View Post
    Problem solved!
    Hmm, it works, but different people have different methods of expressing displeasure. Back when I had my old falcon with the horn on the indicator stalk I used to enjoy applying the high beams and horn with one hand, with both middle fingers up and head out the window screaming obscenities at the moronic tourist who had cut me off on the roundabout forcing me to come to a sudden halt. Used to happen at least once a month due to a "confusing" roundabout. Well it confused moronic tourists anyway, when they did it to me it ended up terrifying them. I like to think I was performing a community service by educating newcomers to the area as to the dangers of approaching roundabouts without proper caution. Anway, I digress. The horn is fairly important should you wish to pass a roadworthy examination of any kind. So your method of communicating danger to other drivers, whilst perfectly acceptable to the vast majority of sensible people is not legally acceptable.
    Yeah, kinda bored at the moment, this finite element analysis I've been running for the last half hour is still processing. If I've gotten a parameter wrong I'm going to scream.
    EDIT: It just did the next best thing, hit 90% complete and crashed due to an alleged I/O error. Smooth with a capital SMOOTH.
    VN Calais no more
    Sep 2006
    Horn is my favourite accessory too!
    Air horns also are very good..
    Not the shitty godfather theme either, but i mean the big F**K OFF beep!
    Hehe
    Not just tourists, but old people, dark people, light people, retarded people, P Platers... really just anyone that belongs to a minority group that you can discriminate against when they drive like idiots!
    pandaman's Avatar
    VN Berlina 5.0 A4
    Feb 2006
    Quote Originally Posted by VNCalais98K View Post
    Hehe
    Absolutely, hell I'm even happy to use it on majorities! Self satisfied scumbags.
    VN Caladore
    Aug 2006
    Yeah pulled it apart.. Is earth related... I couldn't get the boss off, so have wired up a temp fix till I get some more time to have a crack at it....
    cohn's Avatar
    VN Calais Turbo
    Nov 2004
    Penrith
    I hade the same problem of not being able to remove the boss off, i was at work today and i got the bearing puller kit onto it, it was on there that tight that i cracked it completely into two seperate parts, had to get the splice clamp onto the rear part to get it off. so now i have to go and get a new boss kit and i dunno if the horn part comes with it or not so i might have to stop at the wreckers while i'm out, not looking forward to that cause its just rainned and spose to keep rainning tomorrowz.
    VN Caladore
    Aug 2006
    I am meant to pick up my other car from the mechanics on Tuesday/Wednesday and planned to drop the commy off to get a service and the air con checked... So I may just leave it for him to fix... I really could not be bothered.. I still have to re-try and put the dash in... It is just not sitting flush along side the door and front windscreen on the drivers side....
    I will never replace a dash ever again ... Easy to take out, but a real pain to put back in... Grrrrrr
+ Reply to Thread
  1. VN commodore speedo and horn not working
    By kjr in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-03-2007, 08:17 PM
  2. Replies: 3
    Last Post: 03-02-2007, 09:51 PM
  3. Vy Horn Not working
    By batesey323 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 14-08-2005, 01:06 PM
  4. Horn In a VL
    By Trewman in forum Electrical Wiring / Questions
    Last Post: 19-01-2005, 12:08 AM
  5. Horn not working!
    By mrVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-12-2004, 10:42 PM
