Results 1 to 16 of 16
Thread: Out of ideas
    VH V8
    Nov 2005
    Default Out of ideas
    Hi everyone, I,ll get straight to the problem at hand and thanks in advance to the people who get to the end of this post.
    I just got my car dyno tuned (VH with VN injection unregistered), when I pulled it off the trailer it was running great up and down my street with not a hint of a problem. Then something went wrong, here are the sequence of events.
    Between putting it in the garage and starting it the next time all I've done is wrapped some cables with heat sheilding tape and double clamped my fuel lines, inlet and return being careful not to clamp the fuel supply.
    When I went to start it the next time the battery seemed dull but it started and I let it idle for a while and then gave it a rev and it ran like a bag of shit like it was flooding or missing real bad.
    So I did some preliminary checks and found the alternator was shagged so I replace that and still no good.
    Then I started checking leads and coils but the spark seems good and the leads have good resistance values and there is a good spark.
    Then I checked all the sensors for resistance values and voltage values as by the manual. and all check out fine. Yet to do the o2 sensor.
    Fault code 12 showing in diagnostic mode so all OK.
    When I rev it, if I give it a quick stab to full throttle the thing bogs down and won't rev over 2-3 thousand and black smoke coming out of the exhaust. But if I gently bring the revs up it will got to full revs but coughing and spluttering all the way.
    The plugs are black as the ace of spades so I am definitely getting fuel, just too much of it or not enough spark.
    Here is the tricky part, when I disconnect the MAP sensor wiring the thing comes back to life, revs freely and no bogging down.
    Remember I haven't checked the o2 sensor.
    Does anyone have a suggestion as to what this is?
    Has anyone seen this before?
    A bit confusing when the MAP sensor wiring is disconnected and it goes good seeming that this sensor is a major part of the system.
    Thanks
    Rob.
    vt1538's Avatar
    vt1538 is offline 455rwhp LS3
    VY SS S2 11.284@125mph
    Sep 2005
    The Dead Centre
    When the map sensor is disconnected the ecm will go to a look up table referencing throttle position to meter the fuel.
    Sounds like you may have caused a wiring issue when you wrapped the wires.
    When you run it with the map sensor disconnected then did you get a trouble code?
    VH V8
    Nov 2005
    Haven't checked that, I've been too busy trying to find a hard fault that may be the problem. I will check that this arvo when I get home from work. I may have to unwrap those wires and see what has gone on there. The funny thing is that the wires I wrapped were only feed and ignition wires to the starter motor which also incorporated the o2 sensor wire.
    Thanks for the input and I will let you know what comes of it.
    Rob.
    vt1538's Avatar
    Sep 2005
    The Dead Centre
    VH V8
    Nov 2005
    No, I have checked and double checked hoses, sensors etc. Would you know if the o2 sensor would cause it to run so rich. Or is it just a sensor to let you know that you have a rich or lean condition?
    vt1538's Avatar
    Sep 2005
    The Dead Centre
    The O2 sensor has no input until the engine gets over 40 deg & the exhaust is hot.
    When it starts generating a signal it is used to trim the fuel to the set air fuel ratio. So basically no. While a faulty sensor can cause the engine to use excessive fuel it doesnt appear to be your problem.
    Have you checked your fuel pressures ?
    VP V8 Calais
    Nov 2004
    I agree with vt1358. Sounds like the MAP hose has been disconnected from the manifold so the MAP sensor is receiving no vacuum indicating to the ECU that you've got it floored, therfore the ECU pumps heaps of fuel. Removing the MAP wiring plug fixes the problem as the ECU no longer relies on the MAP value.
    You said you have checked the hoses. Have you actually disconnected the hose from the MAP sensor at the MAP sensor, not the manifold, and checked for a valid vacuum signal?
    VH V8
    Nov 2005
    No I haven't, and I haven't the facilities to do so. Are you thinking that the fuel regulator has shit itself and is letting in more fuel than it should?
    If so that wouldn't explain the car behaving normal when the MAP sensor wires are disconnected .
    It's like everything I've tried so far, think it might be spark or fuel but then it run well without the map sensor. It sort of blows every theory out the window. This is the frustrating part it feels like it should be the MAP sensor but then when I back probe the MAP sensor it has 4.8 volts with no vacuum and when I suck on the pipe the voltage goes down like it should so that tells me that the MAP sensor is good. When it is backprobed during idle it wavers between 2.7-3.2 ish because of the bad idling.
    Here's another theory to run by you, the wires that run to the distributor if they have been disturbed could that mean that the timing is not being advanced and therefore perform like it is.
    Hang on disregard that last theory because when I disconnect the MAP sensor it all run OK.
    See how frustrating it is.
    Appreciate the feedback
    Rob
    VH V8
    Nov 2005
    Yes I have disconnected the hose and there is a valid vacuum signal and this is indicated by the voltage received when the MAP sensor is backprobed when idling in the earlier post you may have missed, 2.7-3.2 ish volts. The one thing I haven't done is backprobed the MAP sensor signal at the ECU but it should have the same voltage as at the sensor itself but stranger things have happened.
    The way it looks is the MAP sensor supplies approx 5.0v with no vacuum and approx 2.5ish at idle so I believe the signal from it to be correct.
    Thanks
    Rob.
    vt1538's Avatar
    Sep 2005
    The Dead Centre
    First thing that I would do now is remove the shielding from the wires & see what happens.
    Running a current next to a signal wire can sometimes cause interference. This mainly happens with the coil or pip signal wires.
    I am not sure on the V8 set up for wiring. Is there a start signal wire from the starter to the ecm? If so has this been put back on the right terminal?
    VH V8
    Nov 2005
    I'm about to knock off and go home, yesterday I bought a new coil, leads and plugs just in case so I will change them in the process. I will take the heat sheild tape off the cables and inspect them and see what happens also. I'll let you know how it all went.
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    make sure you didnt' knock the distributor out of whack while playing fuel lines dude!!
    sounds like the timing is ouuuuuuuuuuuut
    VH V8
    Nov 2005
    Running a bit better fellas, with new coil, leads and plugs. Removed heat sheilding tape. Ran it up the street and it's OK but it bogs down at low revs then frees up in the higher revs. Like VP_Luke said it feels as though the timing may be out(retarded) down low. The dyno guy said he couldn't get much timing into it and said I must have a heap of compression. But my mate told me he only put about 9.5:1 in it. Idling smooth but erratic (if that makes sense) sits on 850 for a while then changes tune and sits on 1000-1100 for a while consistently back and forth.
    When I give it a quick squirt it still doesn't like it but if I'm easier on the throttle it behaves normal.
    May have to ring the dyno guy and see what he reckons.
    VP WAGON V6
    Mar 2006
    ide say timing as well or MASSIVE vac leak.
    - OWA650 -
    "Blown Vr wagon, 275hp at the wheels.. Much more to come in the near future!"
  15. #15
    FXST01's Avatar
    FXST01 is offline The Grey Man
    VP V6 Auto Sedan
    Jun 2005
    El-Arish-Shamal-Sina-Egypt
  16. #16
    VH V8
    Nov 2005
    Fellas, the fuel pump is behaving differently now then what it was and now all is OK. So it was the fuel delivery side of things. Will have to keep an eye on things (earths etc.).
    Thought I might let you know as alot of posts here don't quite finish with the end result.
    Thanks for all your input vt1538 and Chuff.
    See you at this years SUMMERNATS.
  1. VT air con ideas
    By craigvk in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-04-2007, 08:09 PM
  2. Some ideas
    By VS Omega in forum Site Feedback / Site Problems
    Last Post: 06-11-2006, 08:44 PM
  3. Ideas anyone
    By SVZ in forum VL Holden Commodore (1986 - 1988)
    Last Post: 11-10-2006, 05:36 PM
  4. need ideas
    By drans_vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-08-2006, 05:57 PM
  5. New VS Ideas
    By mattman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-03-2006, 10:34 AM
