Results 1 to 20 of 20
Thread: Detonation Sensor?
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Default Detonation Sensor?
    hey guys, just wondering something, my engines idling badly, it will idle fine under load but throw it in newtural and it will idle fine then kinda knock every few seconds, (miss a beat if you will) could this be caused by a faulty detonation sensor??? im looking into making my engine run the best it possibly can before i boost it
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    sounds like a misfire more than anything
    cracked plug maybe, a plug tracking, bad lead...
    Rob
    VP Executive R-spec
    Jan 2005
    I haven't heard a vn v6 that idles without missing a few beats every once a and a while yet but good luck !
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Quote Originally Posted by greenfoam View Post
    I seem to agree with Greenfoam.
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    yeah this is bad tho sometimes stalls, yeah might change the plugs as leads were done recently
    VY S2 Berlina
    Jul 2005
    Wide Bay, Queensland
    yea plugs, leads are nromally the 2nd thing i do coz they cost more :P
    btw wat is a detonation sensor?
    Current: My Ride
    VY Series 2 Berlina, Leather
    Previous: Ride 2
    VR Executive, 5 Speed Manual, Ecotec 3.8
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Quote Originally Posted by fitzy2005 View Post
    in other words a knock sensor, it retards the timing when a "knock" develops in the engine to lower the revs and protect itself
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Isnt the meaning of detination when the engine cylinder ignites the fuel before the spark does, it ignites it because of the existing heat and pressure?
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    nah knock sensor detects when the engine missfures ect and lowers the rpm ect
    VP Executive R-spec
    Jan 2005
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    Quote Originally Posted by PaRaDoX616 View Post
    It detects detonation, which in turn it then pulls timing out.
    AirStrike
    Selling FG G6E Turbo and buying a N/A Supra
    xcop5l's Avatar
    xcop5l is offline 4th year spanner spinner
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    Quote Originally Posted by AirStrike View Post
    AirStrike
    thats rite it detects detonation/pinging.
    when did you last have your injectors cleaned?
    Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
    MY RIDES
    [SIGPIC][/SIGPIC]
    http://forums.justcommodores.com.au/...ad.php?t=41837
    VP Executive R-spec
    Jan 2005
    Paradox have you researched what detonation is yet, because you know I don't want to have to tell you
    P.S you can also research what pre ingnition is while you are there
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    thats basicly the same thing
    isnt it?
    MY RIDES
    [SIGPIC][/SIGPIC]
  15. #15
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
  16. #16
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    Pre ignition is when things like the valves are worn and the igntion is firing before the cylinder has filled correctly aint it? So there for its still partially filled with shitty exhaust gasses..........So yeh detonation
    AirStrike
  17. #17
    VP Executive R-spec
    Jan 2005
    Detonation is when fuel explodes hardcore instead of burning, I have a nice fun video somewhere of a badly tuned/bad running VL turbo doing a nice impression of detonation about 3 seconds before it chucked half the motor out onto the track :P. WrrrrreEAAAAAAputAputAAAAAAH put put BANG BANG BANG put BANG crunch, dead. Something like that.
    pre ignition is just when it catches fire before it should have, from the timing being wrong or a overheated motor/carbons all that stuff they are both the same kinda thing in that one can cause the other but detonation is a whole lot more serious than a little ping here and there because it will kill the motor and really fast
  18. #18
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Reminds me of brothers 202, it has a fairly large carbon build-up and tended to "run-on" after the ignition was switched off, sometimes even up to about 10-15 secs if it was hot
  19. #19
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    from what i understand pinging/detonation is caused when the a/f mix is compressed
    and the heat in the carbon cause a flame to come from the opposite side of the cylinder towards the spark plug. when the spark plug ignites the mixture it starts a nother flame. these flame fronts colide violently and cause the pinning/knocking noise you here. this is also when the top of the piston gets "eaten away".(casues major pitting in the engine). i learnt that 2 yrs ago in tradie so i might be wrong(i might have been sleeping)
    MY RIDES
    [SIGPIC][/SIGPIC]
  20. #20
    VN v6 s2 Berlina 5spd
    Mar 2006
    Quote Originally Posted by vn6pwr View Post
    built in turbo timer, lol
  1. VN S1 Coolant sensor - Will a V8 sensor fit/work in a V6?
    By mulligan-can in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-05-2007, 09:08 AM
  2. o2 sensor
    By Matty o in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-08-2005, 09:55 PM
  3. detonation sensor issues
    By iwishmyVNwouldstart in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-06-2005, 11:42 AM
  4. VR V6 TPS Sensor
    By Stugutz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-03-2005, 05:06 AM
  5. o2 sensor
    By VLACS in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-02-2005, 01:50 AM
