Results 1 to 6 of 6
Thread: brake master cylinder leak
    VN Berlina 3.8
    May 2005
    Default brake master cylinder leak
    hi guys got my self a yellow stiker the other night. the guy at the pits rekons i have a leak from the rear of the master cylinder. is there a seal back there or mayb the bolts need tighttining. whats inolved in taking the whole untit off and checking is there anything i need to no
    any help would be appreciated
    Dan355's Avatar
    Dan355 is offline Go THE SS's
    Street Legal 355ci VN SS - Daily: VP SS
    May 2006
    Yea theres a seal there with a circlip by memory. I think theres a few seals there actually. You just need to undo your lines etc then the bolts, then shes out. Pretty easy. Just buy one a recon one saves alot of time and hassle.
    xcop5l's Avatar
    xcop5l is offline 4th year spanner spinner
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    unless youve had alot of experince with brakes dont pull the master cylinder apart bits will go every where.
    from memory theyre not that exspenive. and it costs about 30 to fit
    Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
    MY RIDES
    [SIGPIC][/SIGPIC]
    http://forums.justcommodores.com.au/...ad.php?t=41837
    J_D
    J_D is offline
    VN S1 and VS V8 Statesman
    Jul 2006
    Ipswich. QLD
    Just pulled my old one apart today and they are simple as, the part that usually leaks is just a plunger and one return spring behind it. Just undo the circlip and the plunger will pop up, lift out the plunger and it has two rubber seals on it. As long as the bore isnt damaged you can just replace the two seals on the plunger and put it back in.
    I thought it was difficult also, so I bought another master cylinder from the wreckers (15/16ths as I couldnt find a 1inch one to replace mine), now I might get the two seals to put in my 1inch one and put it back in.
    Im not a complete idiot, some parts are still on backorder!
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    they are difficult to put bac together if you put one of those seals in the wrong. or one of those cups in wrong. or the bore of the master cylinder isnt cleaned and polished so its shiny. you will not have any brakes
    MY RIDES
    [SIGPIC][/SIGPIC]
    Aug 2004
    master cylinder is on way out.. best get the cylinder replaced.
    AP
  1. Replacing Brake Master Cylinder
    By dufus in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-04-2007, 09:48 PM
  2. VN-VP 1" Brake Master Cylinder
    By AlpineRaven in forum Parts And Other Items For Sale
    Last Post: 09-02-2007, 08:44 PM
  3. Brake Fluid Master Cylinder
    By Harvs82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-11-2006, 07:19 AM
  4. Leaking Master Brake Cylinder Connecting to Brake Booster Advice help please.
    By IceDHB in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-08-2005, 02:32 PM
  5. executive brake master cylinder
    By seventh path in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-10-2004, 07:04 AM
