Hey guys
as some may know iv been having all sorts of problems with this new car.
it runs fine then it just dies, after trying to start it it gets going after 30 sec of cranking it splutters and jerks and idles like shit an then when i press the pedal it kinda dies down then revs up flat out and blows a shit load of black smoke and smells like fuel and it will run fine over approx 2500rpm then if i drop below that it will do the same thing chug chug black smoke and roooooom.....
Not getting any ECU codes. it done this last week and i went out 2 days later and it ran fine for a week never missed a beat and now its doing it again seems worse this time.
im worried to change coil packs and CAS and Altinators as its a expensive process of eliminaton.
can anyone shead some light onto this subject or want to lend me a Coil pack for a hour :P
GOING INF#$%^&NSANE!!!!!!!!!!!!!!!!!!!!!!!!!! help!
m3taL... for what its worth...
http://s92.photobucket.com/albums/l9...rrent=vn-3.jpg
My Ride
88' VN 3.8 5spd, Custom CAi, 2.5 High-flow zaust && Foaming Tune!!!
Turbo Manifolds and Plumbing Near completion!
Family Ride:
2007 Kia Grand Carnival Lux Model
your barking up the wrong tree all together,
replace fuel filter, if not fuel filter, th en look at fuel pressure regulator on the fuel rail. if that still dont fix the problem, put a injector service threw it.
make sure each injector is firing (you will feel pulse in fingers) dotn worry about spark just check firing of injectors. check your air filter isnt cloged,and throw some carbie cleaner down the throat of the throttle body.
cheers
garth
i am the god of britany spears womanizer on just dance on the wii
To make black smoke you need fuel that hasn't been burned completely and since it takes along time to start, but then does start, it really sounds like a fuel problem and everything points at the regulator to me
Or leaking injectors and check that the injectors are hooked up to the right connector.
Illegitimi Non Carborundum
Makes Sense as to why no ecu codes, Might Go get a Filter tomorrow and a Regulator are they worth much??? then get some Injector cleaner as well, Do Regulators Intermitantly play up before they die????
thanks for the replys seems i was barkin up the wrong tree after all...
My Ride
Family Ride:
If you mean that they are hooked up in the right order, that wouldnt matter on a VN as they arent sequential firing. They all fire at the same time.
Im not a complete idiot, some parts are still on backorder!
cant be the injectors wired wrong as it Runs fine for a week then does it again it done it once before about a month ago then ran fine for a F/night Very intermitant......
My Ride
Family Ride:
I had a very similar problem 2 days ago, after geting it to start (wasnt fun) it would idle ok for me then any hint of semi fast acceration she splutters then just about to conkout then bam she kick back in. Ran FINE over 2500RPM. The reason for my dramas, It was my faulty fuel regulator that was pushing 80PSI pressure instead of 40PSI. I would say you have the same problem. I got ripped off in the end tho, I had to get it fixzed asap and the guy I took it to (didnt know him) charged me $180 for the new regulator and $170 for the laybour!
OK, wasn't sure what the length of time was, when it was running fine.
Ok thinking cap back on.
Mack you got ripped, you know it's only two bolts holding it on just there on the manifold :|
I know I got ripped man. But Hey I didn't know what the problem was and I needed to drive home.
So is it possible that a Fuel regulator would Intermitantly Fault?? or once it go's shhee'bang its F$%^D???????
cos i priced one today $165 from repco... dont want to replace it unless its the issue.. its running fine again today had a bit of a issue earlier but it fixed itself again.. stiull has a slight flat spot when i jump on it and smeels rich too..... im guessin its the reg...... so i will replace it but i just want to know if anyone knows can they be intermitantly playing up for a while????
seems i could be getting somewhere
My Ride
Family Ride:
