just replaced front pads, had to remove calipers now lots of pedal travel ?
Give em a bleed?
Beau Duke: Man, I'm never gonna get outta this car again. I'm gonna live in it, I'm gonna eat in it and I'm gonna make sweet love to it!
Luke Duke: You mean you're gonna make sweet love IN it.
Beau Duke: Oh no, I'm gonna have sex with it.
we replaced front pads and bled them m8![]()
Are they decent pads?
Pedal travel = air in lines somewhere. If you have put new pads in U would have had to push the pistons back in. Did any oil come out of the master cylinder? U had the top off when U push the pistions back in didn't U.
I had the same problem . . . left it overnight and it seems fine now . . .
I just put it down to being a 'first few stops' thing and decided to ignore the problem and hope it goes away.
It did.
Good luck
Sam
it will most likley be air in the system.
also some of the new pads need to be bed in
to bed in brakes take the car out to a quiet road, sit at 60 and brake as normal to a stop. do it again but leave about a min of driving in between for the rotors to cool. do this about 5-6 times
Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
MY RIDES
[SIGPIC][/SIGPIC]
http://forums.justcommodores.com.au/...ad.php?t=41837
yeah ^^
but sounds like air in the lines....
bleeding isnt just a 5 minute job thou..
If Your In S.A (Adelaide) And Have VR/S Parts & VL Parts For Sale
Go Here ---> http://forums.justcommodores.com.au/...tml#post683835
I had the same thing when I done mine, I think it's because you've been playing with the piston and whne started it's gotta build pressure back up inside. I've never had to bleed my brakes after doing them and they've always worked fine afterwards.
if it were air in the lines it still would be spongey. I love doing brakes even had to redo hubby's as he forgot to make sure the spring on the brake pad was lined uplol
^^^You might not have had to do them, but you should bleed them at some point. Brake fluid is like pretty much every fluid in the car. It needs to be changed every now and then.
Gravity is proof that nature keeps getting us down.
