i was thinking last night that if i want VE wheels on my ute would it be as easy as just knocking out the smaller wheel studs and drilling the hole out bigger to accommodate the thicker studs??
i think they have a slightly differnt stud pattern like hz to vb
Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
MY RIDES
[SIGPIC][/SIGPIC]
http://forums.justcommodores.com.au/...ad.php?t=41837
I think the wheels have a different offset to. Why would you want ve wheels? I havnt seen anything decent yet.
as far as i know from hq to all the commodores, the stud pattern is the same. just the offset and the centre is a little different in the kingswoods..
don't know about ve or vz. i would think vz would still be the same...
MY RIDES
[SIGPIC][/SIGPIC]
i have a hq rim on a vh. i will have to go and have a look tomorrow and see if the studs bent
its differnt the other way around because of the bigger studs(fatter)
MY RIDES
[SIGPIC][/SIGPIC]
I have seen warnings about HQ to WB wheels and Commodore wheels on Australian automotive sites for many years. The wheels are not interchangeable. The HQ to WB has the American Chev stud pattern i.e 5 studs on a 4 3/4 inch circle. The Commodore is metric with 5 on a 120 mm circle.
There is about .7 of a millimetre difference and that is enough to eventually break the studs as many people have found out the hard way.
Brian
now i am get ya all... lucky i don't own a kingsy or i would have tried it..
