hey i was wondering if anyone knew y my vn isnt starting, it has no spark for some reason, all i did was take the battery out then put it back in now i got nothin. some have suggested the dfi or crank angle sensor. any help would be appreciated. thanx.
pour some cold water over the crank angle sensor, (located behind the harmonic balancer(biggest pully)) and wait half a minute and start it, if it is the crank angle sensor then it will start but needs to be replace, other than that try somone elses coil pack
yeh mate sounds like a coil pack hey
like whats been said could also be
crank angle sensor
dfi module
battery??
cheers
ryan
apparnetly its not the coil coz if it was then it would start but miss fire also. i tryed the battery in 2 different cars and it wont start either of em. yea its just not starting at all.
Well, if you tried the batt in two different cars, and it started neither, you might almost think your battery could be a little rooted
battery is dead lol
VS SS - Street/Show Project [BEEFY]
http://forums.justcommodores.com.au/...-beefy-v2.htmlHID Kits from $100 - Installation available PM FOR DETAILS
do you mean you tried to other batteries to start yours and it still dont start? but the batteries will start the cars you took them out of? does it crank over at all? does it make any sort of noises? any dash lights? is it an auto or manual? did it start before you took the battery out?
