Results 1 to 8 of 8
Thread: Changing Brake Pads
    VP V6 Executive
    Jul 2005
    Exclamation Changing Brake Pads
    I’m getting 2 set of Green Stuff break pads on Friday. Front a rear, just curious if i need a special tool or anything to pop the old ones out and put the new ones in. Also any tips or advice would be great.
    Thanks guys
    Nick
    dmitch's Avatar
    dmitch is offline DonkeySS
    VS SS S2
    Oct 2005
    Perth W.A
    use a clamp 2 push it piston back into the caliper but that about it.. other than that they just slot in.. and dont leave the caliper hanging by the brake lines..
    Check out my ride and rate it high plz
    VP V6 Executive
    Jul 2005
    dmitch's Avatar
    VS SS S2
    Oct 2005
    Perth W.A
    oh yeah and u will have 2 remove about 1/2 of the fluid from the res to prevent overflow when the piston is pushed back in.. but dont remove it all or u will have 2 bleed the brakes
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    Worth bleeding the system anyway if you have the time. Especially if you're going to be throwing such high-quality pads in there...might as well have nice new fluid to go with them,.
    Gravity is proof that nature keeps getting us down.
    VN Commodore
    Feb 2006
    VP V6 Executive
    Jul 2005
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Put a bit of grease on the slides while u have the calipers out.
  1. changing rear brake pads
    By lizard199 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-11-2007, 06:48 PM
  2. Brake pads changes.
    By Krustyone in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-07-2006, 11:02 AM
  3. Changing brake pads
    By me_011 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-06-2006, 03:56 PM
  4. Brake Pads
    By Jules86 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-10-2005, 08:53 AM
  5. Brake Pads
    By BagEmUp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-02-2004, 01:18 PM
