Results 1 to 16 of 16
Thread: got a new problem with automatic
    Aug 2004
    Default got a new problem with automatic
    I cannot reverse!!
    That only occurs when the engine/trans is hot after driving for a while, if its cooled down/or local driving its fine.
    D, 2 and 1 (all forward gears) are fine but when you select reverse, there is nothing like being in netural! What could be going on?
    AP
    SlowVac is offline Owner of a SlowVactioner
    VN SII
    Mar 2005
    Have you checked your tranny fluid? If the fluid is full take it to a transmission specialist to determine the problem.
    dmitch's Avatar
    dmitch is offline DonkeySS
    VS SS S2
    Oct 2005
    Perth W.A
    transfuild, loose linkages, could get a transcooler to help overheating.
    Check out my ride and rate it high plz
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    sounds like it's a little more serious then a fluid problem but a trans cooler never hurts
    Body by Holden, Soul by Brock
    the Legend will live forever
    Aug 2004
    that what my mechanic said.. he added some wynns stuff in it (he wouldnt show it to me because he knows i have a big mouth) and said to me drive it for a day then you'll be fine. Transmission is full also said to add transmission cooler in!?? Does anyone recommend to add cooler?
    AP
    J_D
    J_D is offline
    VN S1 and VS V8 Statesman
    Jul 2006
    Ipswich. QLD
    Definately add the cooler. It will increase the life of the transmission.
    Im not a complete idiot, some parts are still on backorder!
    VP Executive R-spec
    Jan 2005
    I used to loose 1st gear in the HQ when the fluid got low, sucks being at a intesection with no forward gears in a stumbling old 253 :P
    Aug 2004
    Quote Originally Posted by AlpineRaven View Post
    AP
    will turn ur seals and shit to mush that kinda stuff if its not selecting gears etc it ****ed most likely.
    i wouldnt bother if its a standard car with a standard auto only if you thrash it all the time get a cooler
    Apr 2006
    Auckland NZ
    unless you drive like a granny(and i bet there aren't a lot of grannies on this forum), fit the cooler. something i noticed in another thread about ADLD cables and data logs is that almost everybody trying this is getting an auto over temp flag comming up. i'd suggest that the standard trans cooler in radiator setup is a poor design. fitting an extra cooler certainly won't hurt the tranny, might hurt the wallet a little but it's and extra insurance policy for your box
    Apr 2006
    Auckland NZ
    unless you drive like a granny(and i bet there aren't a lot of grannies on this forum), fit the cooler. something i noticed in another thread about ALDL cables and data logs is that almost everybody trying this is getting an auto over temp flag comming up. i'd suggest that the standard trans cooler in radiator setup is a poor design. fitting an extra cooler certainly won't hurt the tranny, might hurt the wallet a little but it's and extra insurance policy for your box
    Aug 2004
    Quote Originally Posted by immortality View Post
    Got a cooler from wreckers $28 will fit it tomorrow and will give trans a filter change & service at the same time that way i can fit in new fluid and give it a go?
    AP
    xcop5l's Avatar
    xcop5l is offline 4th year spanner spinner
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    a cooler wont fix the auto it will only stop it from over heating.
    it will most likley be the clutches/bands have passed there use by date and have said i wont work any more
    Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
    MY RIDES
    [SIGPIC][/SIGPIC]
    http://forums.justcommodores.com.au/...ad.php?t=41837
    Aug 2004
    hmmm... I gotta go to auto specialist... That is why I dont like automatics!!
    Anyway, Just went out after driving over 240kms today (from here to Ballarat drop some stuff then back here in Melb) when arrived Ballarat & Melbourne reverse didn't work due engine is hot, i didn't really drive hard.
    Its been half hour since I arrived home I checked out, I can reverse and it doesn't take ages to "click" in reverse just goes in reverse like 3 secs from park. Tomorrow will change the filter and add new oil in and see how I go on Sunday when I drive to Geelong, if it still not right then I'll take it to transmission specialist, mightbe the gearbox is on its way out.
    AP
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    change your filter as well
    MY RIDES
    [SIGPIC][/SIGPIC]
  15. #15
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    Check your reverse solinoid...
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
  16. #16
    Aug 2004
    Ok, So far so good...
    Changed the filter $16 (kit with filter and gasket) and fluid $24 from Bursons. Also added Transmission cooler.
    Drove to Ballan (after Bucchus Marsh) and back - reversing is working while hot!
    Today drove to Geelong then back - Reversing again working well.
    Fingers crossed that it'll be okay?!??
    Fluid was dirty when drained it (not bright red - brownish redish colour - may have explained why it wasnt working well!?.)
    Thanks for your imput guys.
    AP
  1. VN Automatic 1st 2nd ok 3rd problem
    By madmatt2006 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-01-2008, 11:33 AM
  2. Automatic Transmission Problem (VXII)
    By myberlina in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-04-2006, 04:27 PM
  3. automatic engine fan
    By 90VN55 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-04-2006, 12:37 PM
  4. Automatic Transmission Problem
    By savage1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-03-2006, 09:52 PM
  5. Automatic Gearbox
    By VTSSDUDE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-11-2004, 10:57 PM
