hey, my mate thinks i have a "non standard" cam in the car,
sounds a bit louder under acceleration(exhust note) than stock and is quicker than my brothers exec despite being like 100kg heavier, it also gets through the rev range pretty quick, and on stock tune @ full acceleration valve bounces a bit... also when i got the ecu changed over the car didnt run as good, (was a newb back then and got a shop to do it) so if it had a memcal for it then it coulda been swapped for stock.... also the car does not like 91 octane, pings like hell, but loves 95/98 octane...
i suspect this car was used alot for towing before i got it as the rear bumper had lots of scratches on it..
this is using a stock tune
is there anyway to tell if the cam has been changed??
http://www.youtube.com/watch?v=d7vYB1k88oY
http://www.youtube.com/watch?v=8Zr4SF7Djxk
heres a few video i filmed last night
is there anyway (without ripping it apart) to find out the valve lift ratio's???
yeah get a dial indicator and check your lift on your intake and exaust and compare it with stock
all you have to do is pull one rocker cover off.
also make sure u run it first so it has oil pressure other wise the lifters will bleed down and you wont get the rite reading
Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
MY RIDES
[SIGPIC][/SIGPIC]
http://forums.justcommodores.com.au/...ad.php?t=41837
how much do dial indicators cost and where would i get one from???
so bascially crank it over with the plugs dissconnected similar to compression testing???
Dont crank it, wind it over by hand
aight, where would i get a dial indicator from and how do u use it???
you can get them from tool shops for about 30 to 40
yeah you have to wind it over slowly to get the reading
if you were close to me id show you how to do it.
this test only tells you what lift it has not the duration
MY RIDES
[SIGPIC][/SIGPIC]
ahh k, well ill get vp luke over or next time he goes out ill get phone credit do i dont end up near hallam :P rofl
anyway ill get a gtech run
