Results 1 to 2 of 2
Thread: fuel reg
    VN v6 s2 Berlina 5spd
    Mar 2006
    Default fuel reg
    hi
    well since i bolted my sc14 on i noticed it runs a little lean.
    i have been told to purchase a rising pressure fuel regulator.
    my question is which would be the best type if i choose to up the boost with some bigger injectors.
    and what happens to the stock fuel reg?
    does it come off or stay on?
    is there some sort of adapter i can use to attach a regular fuel hose directly to the fuel rail if the stock reg isnt there?
    J_D
    J_D is offline
    VN S1 and VS V8 Statesman
    Jul 2006
    Ipswich. QLD
    You cant run the system without a fuel regulator as the computer relies on a certain pressure to deliver the correct amount of fuel. You would have to take off the old reg to run the new one. I dont know what regulator to run.
    Im not a complete idiot, some parts are still on backorder!
  1. fuel surge turning right? weird inst fuel readings
    By vkotis in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-10-2006, 12:00 PM
  2. leaking fuel damper and fuel pump adventures
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-08-2006, 04:00 PM
  3. fuel injected 5ltr motor setup for dual fuel
    By ma77es in forum Swap / Wanted to Buy / Trade
    Last Post: 28-05-2006, 07:03 PM
  4. VS Internal fuel pump issue (duel fuel)!!!
    By futronix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2005, 08:10 PM
  5. Steel Fuel Line Into Fuel Rail Question
    By VTSSDUDE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-09-2005, 09:50 PM
