+ Reply to Thread
Results 1 to 10 of 10
Thread: Which Pads???
    VN Calais 5.0/vy sv8/r31 rb20
    Oct 2006
    sydney
    Default Which Pads???
    Hey guys, I have just done the brakes on my vn calais with slotted front and rear disks and i used lucas pads on the back and Bendix general ct on the front but they dont seem to pull up as best as i expected. a friend of mine just put ebc green pads on his subaru and they work excelent with plenty of feel. wat do you use and recomend?
    VP Exec,Gsx-R 750
    Mar 2005
    Oct 2006
    sydney
    Doctor Sodways's Avatar
    Doctor Sodways is offline Legendary Baby! Doctor Sodways Calais
    Slammed VeeDub Rat and a Brunette...
    Sep 2005
    Behind a Camera...
    green stuff is a highly recommended pad, no brake dust either, red stuff is your track orientated pad, so unless they get hot enough, they wil squeal, bendix unltimate are highly recommended, but produce a lot of dust
    hope that helps
    I used to play sports. Then I realized you can buy trophies. Now I’m good at everything.
    The best car safety device is a rear-view mirror with a cop in it. ~ Dudley Moore.
    dmitch's Avatar
    dmitch is offline DonkeySS dmitch Executive
    VS SS S2
    Oct 2005
    Perth W.A
    i use bendix ultimate but there is alot of dust... ferodo r good aswell and not as much dust as the ultimate
    Check out my ride and rate it high plz
    xcop5l's Avatar
    xcop5l is offline 4th year spanner spinner xcop5l Executive
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    lucas arent the best pad. they produce major amounts of dust.
    bendex ultamates are the pad i use. exelent stoping power.
    ebc green are just as good if not better
    Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
    MY RIDES
    [SIGPIC][/SIGPIC]
    http://forums.justcommodores.com.au/...ad.php?t=41837
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked... HoZy W427 HoZy W427 HoZy W427
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Just helped my bro...
    New set of DBA GOLD Slotted & X-Drilled rotors On the rear... with Bendix Ultimate pads.
    MaT
    P.S- Pic after we BED them in...
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    Oct 2006
    sydney
    thanks heaps guys i think i will go the ebc greens they work fantastic on the subaru. its funny though the rears lock up quite easily in the dry in hard braking but i think it could just be poor choice of pad but thanx alot guys
    SlowVac is offline Owner of a SlowVactioner SlowVac Executive
    VN SII
    Mar 2005
    I'm running greenstuff with DBA x-drill slot rotor all round with the VT front setup for over 6 months. Definatly better then the ultimate pads in dust and braking and slightly lower rotor wear (got brake fade after 4 hard braking, greenstuff none so far).
    QFM is good pad where it doesn't release much dust but not very good to the rotor causing it to warp and serious brake fade with my experience.
    knowledge_is_power's Avatar
    knowledge_is_power is offline Quest for Cognition knowledge_is_power Berlina
    VT SII V6 A4
    Oct 2004
    Nth Brisbane
    Quote Originally Posted by HoZy View Post
    That would have to be the aggressive bed in procedure I have ever seen. I have seen this after track use or mountain decents, but for bed in it’s a little over the top.
    Just so everyone knows, the idea of bedding in is to set the glues in the pads and get a clean surface ready for brake applications. You will reduce the efficiency of your disc pads is you over heat them during bedding in.
    To bed in a new set of pads you accelerate to 50 - 60kph and brake till your doing 10kph then accelerate (not like a drag race) and brake again to 10kph. You should not come to a complete stop if you can help it. Repeat this 6 - 8 times. Never hold the brakes on while accelerating, and never bring them to the point where they start to smoke.
    The idea is to get the pads to a good temp and hold them there for a period of time.
    Back on topic: The bendix CT's are a pad for mums and dads. If you want performance braking you'll need to get a pad with a higher friction rating like Ultimates or simular. Remember everything is a compromise. More friction gives quicker stops, but will lead to increased pad and/or rotor wear, and in most cases more dust.
    Jezz
+ Reply to Thread
  1. Brake Pads
    By ssmate in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-10-2006, 09:56 PM
  2. Which Disc Pads to buy??
    By Jock in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-08-2006, 08:24 AM
  3. any good (pads)
    By phat_com in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-06-2006, 11:25 PM
  4. Brake Pads
    By Jules86 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-10-2005, 07:53 AM
  5. Brake Pads
    By BagEmUp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-02-2004, 01:18 PM
