Results 1 to 13 of 13
Thread: how low can i go ??
    beefcream's Avatar
    beefcream is offline Lethal LOKKA
    VS SS 5speed (project) VN exec v6 (daily)
    Sep 2005
    South,Adelaide
    Default how low can i go ??
    hey all
    atm im runnin king supers in the front and king ultra's in the rear
    i dont mind how the front sits but still not happy with the rear, im thinking of compressing my ultras 1inch down and run short stroke shockers and adj panhard rod.
    also i need to redo front cause left bearin plate is stuffed. should i run ultras in the front and will it lower much more than the supers??
    cheers
    VS SS - Street/Show Project [BEEFY]
    http://forums.justcommodores.com.au/...-beefy-v2.html
    HID Kits from $100 - Installation available PM FOR DETAILS
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    take one of your ultra lows, cut it quarters and put each quarter for each corner of the car.....
    or compress your springs :P
    compress the supers man, hakhawk runs ultra's and they arnt much lower at the front so compress em
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    beefcream's Avatar
    Sep 2005
    South,Adelaide
    if i replace with new rubber strut tops will i get a huge rise ? and how much can u compress the fronts and rear be4 i start running into problems?
    hakhawk's Avatar
    Jan 2005
    u will get a rise of about 1-2cm with new tops., but also depends on how bad old ones are.
    not sure how far u can compress springs before problems, but obviously when it starts bottoming out too much ur in trouble.
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    I have ultralows in the front... I'll get you some pics...
    Why go lower in the rear though? It looks like one of 2 things... Either you have very old saggy springs in the rear or you have chopped your rear springs. Plus its bad for the handling of the car as well.
    1991_Vn2nV's Avatar
    Mar 2006
    Remembering these are Lovells Ultralows, slightly lower than the King Spring version...Had some issues with scrubbing on the front guards, but a home rolling job fixed that, though it still happens on steep slopes where i go sideways cause of the kit... But they are 245 tyres also, so smaller tyres probably wont have the same problem.
    Pics:
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    vn2nv, you should change the pic in your sig to an updated one with the rims it has?, had? on in those pics. They look ten times better.
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by vn6pwr View Post
    I want to, and I took a pic like the exact same but with the new rims... But my camera wont let me upload the pics to my laptop
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Yeah, looks nuts mate. I bet you cant wait till you get the other side fixed!
    beefcream's Avatar
    Sep 2005
    South,Adelaide
    hey all,
    just need some closure on a question... attached is how i want the rear to sit, atm this is 1.5inch below wat it is now. i need to know will short shockers be ok an d wats the likleyness of the spring to fall out? wat else do i need to do for it to be safe?
    Attached Thumbnails Attached Thumbnails how low can i go ??-dsc00903-large-.jpg
    1991_Vn2nV's Avatar
    Mar 2006
    You're not talking about cutting the springs are you?
    Looks just like Lovells Ultralows to me, same height my car used to sit at at the rear...Maybe even lower.
    beefcream's Avatar
    Sep 2005
    South,Adelaide
    no not cuttin.. getting them recompressed today
