Results 1 to 15 of 15
Thread: aerial
    vn s2
    Jan 2006
    Default aerial
    i brought a aeropro after market electric aerial does anyoneknow the wireing for it???
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Did your car come with an electric aerial or not? If it did you just need to connect it to the wires from the aerial module, if not... Just wire it straight to the headunit because you dont have the buttons anyway.
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Try this http://forums.justcommodores.com.au/...0&d=1117703288 its for the module if the buttons arent in your car dont run the wires for them.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by markovr View Post
    The VN modules (theres 2 or 3 for the VN series) are incompatible with the Aerpro aerial anyway.
    vn s2
    Jan 2006
    my car didnt come with a electric one. there is a black wire,a red wire a green wire and a black with white stripe not sure which one goes where as i didnt get instructions
    1991_Vn2nV's Avatar
    Mar 2006
    vn s2
    Jan 2006
    vn s2
    Jan 2006
    the aerial has four wire's 1 black, 1 black with white stripe, 1 green and 1 red. black and black and white both earths, green goes to remote wire on cd player,red goes to constent power
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Mate I got mine installed for $50. Worst comes to worst, that's all you'll be up for. Any stereo shop should be able to do it for you. By all means, have a crack at it yourself though!
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by savage1987 View Post
    I bought my Aerpro Aerial for $80 at JB Hi-Fi, and they said $30 to fit it, so I agree. Worst comes to worst, just get it done professionally.
    1991 VN V6 Executive Series 2
    Oct 2006
    My aerial is stuck in the up position....I guess I'll have to pull the wheel arch lining off to have a look at it. The aerial seemed in good nic before it stayed stuck....Does this sound like something that can be fixed with a bit of tlc (a bit of lube and a movement)? I can hear the motor? whirr and clicking sounds like it is working normally when I turn the radio on, but of course the aerial is stuck in the up position. Whereabouts is the aerail module? I had a look at the link you posted markovr.
    PS. I dont like they way the aerial comes up on the vn everytime you turn the radio on - ie even to just look at the time or play a tape.
    Cheers for your help.
    1991_Vn2nV's Avatar
    Mar 2006
    Thats why theres so many problems with the aerials... They go up and down all freakin day, wears them out.
    Might have broken one of the gears in the motor. Would not be the module if it will not move at all. Its either the mast, motor or one of the gears.
    vr
    Dec 2006
    Default aerials
    anyone know how to replace the aerial. Some %$#@er broke it off at the base. Do you have to take off the wheel arch or something?
    Oct 2006
    do a search for aerials in this forum chopper........there's a few posts that tell you what to do.
  15. #15
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    I have an areo pro in my VP now i think the motor is stuffed previous owner said it never worked 4 him either now i took it out n this is wat i found theres only 3 wires i black (which is spliced 4 some reason with another black wire) 1 red and 1 green. if i were 2 hook it straight from the car battery would i hear the motor no matter which red or green wire i put the +ve wire on or do they both need power 4 the motor 2 work?
    my next question is the module? does ne1 have a pic of wat 1 looks like? i tried finding mine b4 n couldnt find it where its supposed 2 b so i dont think its there? ive also noticed the after market cd players antena wire isnt hooked up either doesnt look like it eva has been b4 if so would this mean it must b wired 2 the module somwhere?
    ne help would b great thanx
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
  1. VT Aerial
    By jamesl_VTSS in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-04-2007, 03:54 PM
  2. car aerial
    By Mr_Calais in forum Car Audio
    Last Post: 12-02-2007, 10:29 PM
  3. aerial
    By StatOmaN in forum Electrical Wiring / Questions
    Last Post: 12-01-2006, 01:34 AM
  4. other aerial
    By Stretchomatic in forum Car Audio
    Last Post: 21-09-2005, 11:51 AM
  5. New Aerial
    By wooly72 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-11-2004, 09:25 AM
