HEy guys
Lately ive started to notice a bad grind when im turning. Sometimes when i turn a round-a-bout its really loud and the steering wheel will shake!
Whats my problem?
Also interested in this... Our VS has started doing this also.
CV joints is what it sounds like
Check your wheel bearings & front discs.
Where's the sound comming from? Got plenty of power steering fluid?
Hokay, I reccomend that you check your wheel bearing end float. Raise one of the front wheels and push/pull it to see if it moves. If there is movement then your wheel bearings need attention. While you're there you might as well check your balljoints as well by grabbing the top and bottom of the wheel and trying to rock it, if there is movement there then the balljoints are munted as well. Hell, why not look for some movement in the rack as well, grab the front and back of the wheel and move it side to side (on the axis it turns on for steering) if theres much slop there then the rack might be a bit worn out.
Beau Duke: Man, I'm never gonna get outta this car again. I'm gonna live in it, I'm gonna eat in it and I'm gonna make sweet love to it!
Luke Duke: You mean you're gonna make sweet love IN it.
Beau Duke: Oh no, I'm gonna have sex with it.
Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
MY RIDES
[SIGPIC][/SIGPIC]
http://forums.justcommodores.com.au/...ad.php?t=41837
Problem solved guys
Power steering fluid was empty'd out
Couldne belive it only had the car for 2 mnths
