in my 1992 vp calais it has a ticking noise from the engine... worse when its cold in the mornings...the mechanic said its probably a sticky lifter does anyone know how to solve this problem if its possible???
thanks heaps
get a bottle of lifter treatment. if that dosnt work new lifters
Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
MY RIDES
[SIGPIC][/SIGPIC]
http://forums.justcommodores.com.au/...ad.php?t=41837
there not too bad to change ova
thanks lads ill try the bottle of lifter treatment but how do i get to them to be able to put the treatment in???
do this first man
remove both rocker covers (6 bolts on eacH?)
then using the correct socket tool unbolt the rockers and remove the pushrods and check either clean them or replace them, i reccomend cleaning then put them back in good as new! im gonna change mine over soon when i can be bothered
i agree. i would only do that if i was replacing the lifters them selvs. the pushrods dont usually make noise, unless the lifter has colapsed
MY RIDES
[SIGPIC][/SIGPIC]
Try Wynns engine flush first. Add to warm engine - run for 15 mins and then replace oil.
Stopped my lifter noise. AND the 'replace crank' advised by 1 mechanic.
That job was going to cost $1,100 for starters + what ever else they could think of.
first of all he asked how to fix sticky lifters if indeed he had them
he also might discover something very distrubing like i did, so sometimes its worth while
my engine was down 1 cyclinder on compression and i ripped the rocker cover off to find a rocker 1mm from comming loose........ also you can check to see if any pushrods are bent, which is the MAIN reason for this exercise....
non mechanical?
well see my understanding was that the camshaft lobes push the lifters up into the rockers to open the valves??? ohh wait Nahhhh they couldnt possibly be related to the valve train at all..what was i thinking..... pfft i must be a idiot!!!!
the problem may not be mechanical problem at all, some injectors especially the vn/vp ones are very loud, cant hurt to remove them and give them a squirt of carby cleaner then pulse them with a battery (9v or something siliar with sufficient current)
Cam lobes push on lifters which push on the pushrods. All they do is push, hence the name. If any are bent, you got more drama's then a noisy lifter
if you do the lifters you have to remove the rocker gear any way,
its best to check all the valve train components when you have a noise in the system. at could be any thing from a loose rocker cradle bolt to a colapsed spring and a valve tapping on top fo the piston to a buggered lifter
MY RIDES
[SIGPIC][/SIGPIC]
it could be some thing simple like no oil
MY RIDES
[SIGPIC][/SIGPIC]
Sounds like PaRaDoX616 is the only one here who realises that the pushrods are hollow for purpose of pumping oil through them to the rockers and lubricating them. If the pushrods are dirty and/or blocked then the rockers won't be getting as much, if any oil that they require, which would lead to a ticking noise being made.
If they are partially blocked then the oil would need to get hotter and thinner to get past the blockage, which may be why you only hear it when the motor is cold in the morning.
Illegitimi Non Carborundum
