Results 1 to 11 of 11
Thread: Knocking in Bellhousing
    Oct 2006
    Default Knocking in Bellhousing
    Ive got a '90 VN v6 manual with a loud knoching from the bellhousing. It only does it just above idle. Ive just put a new clutch in it but the sound was there before. The old release bearing was broken and the clutch fingers were distorted.
    Is the clutch fork supposed to have a big bit of 40x40 bar welded to it? Ive never seen anything like that in a car before.
    VP Exec,Gsx-R 750
    Mar 2005
    Whats your input shaft and spigot bearing like? Does it do it if you put your foot on the clutch?
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    if its a quick tapping sound and it goes away when you apply clutch pressure... then its your pressure plate. Unfortantuly ive been told that it is unfixable. VN fault... Its not an issue with the hydrolic clutches as its a push type and can be adjusted accordingly.
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    Oct 2006
    It does go away when the clutch has pressure on it. The input shaft and spigot were in good condition. The vibration comes through the pedal as well which is annoying.
    VN series II custom :) and VZ exec
    May 2005
    Mildura
    sounds like the pressure plate could be distorted, or a broken spring or something, dont know if that helps, yeah i think the fork is suppose to have that lump of steel on it, like a vibration damper or something, cant remember
    vp v6 commodore executive
    Aug 2006
    south island newzealand
    did you check the height of the clutch fork pivot ball in the bellhousing if this isnt adjusted right the fork could be tapping the pressure plate.From the block face of the bellhousing to the top of the ball should be 102mm and yes that bit of steel is a vibration dampener
    Oct 2006
    Yep checked that. The old clutch had bent fingers. I put a clutch kit in it since it was slipping only to have the same problem and it bent the fingers on a new pressure plate and destroyed the release bearing. I swaped the clutch fork and flywheel for the ones from my spare motor and box and used the old pressure plate from the same motor. So far its reasonibly quiet.
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    adjust pivot to 1"
    this is the main cause
    have u replaced the clutch? most over looked
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
    VS SS 5.0ltr
    May 2006
    queensland
    My vp did it after i put a heavy duty clutch in it. Go to holden parts dealer its needs these little rubber things to stop it hope this helped you mate. It fixed my probelm.
    KEEP IT AUSTRALIAN AND DRIVE A COMMODORE
    Claudy's Avatar
    Claudy is offline French Com
    Manual Gen3 VT SS + V6 VT manual turbo
    May 2006
    Perth, Two Rocks
    is it hard to change the clutch in a VN ?? wats the easiest way to do it as my clutch is on its way out and im gona buy a heavy duty clutch to replace it??? cheers
    VN CALAIS/VT executive
    Sep 2005
    Quote Originally Posted by nz vn View Post
    i'd say, by what you have described,.....what was the flywheel facing like...smooth,rough,any cracks,burn/heat spots? spigot,was it dry?did you replace everything..clutch plate and pressure plate and throwout race?also you may of unintentionally had the gearbox lopsided when replacing it and distorted your pressure plate fingers,or twisted the guts of your clutch plate.now this big chunk of steel you are talking about,on lever,never seen one on any of the VN's i have replaced clutches on,even my calais doesn't have chunks of anything off the lever
  1. Rattle in Bellhousing after changing clutch
    By scoots in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-05-2007, 06:44 PM
  2. WTD, supra 5 speed to holden 6 bellhousing
    By hot308vb in forum Swap / Wanted to Buy / Trade
    Last Post: 22-06-2006, 07:15 PM
  3. v8 bellhousing
    By oyamum in forum Swap / Wanted to Buy / Trade
    Last Post: 13-01-2006, 05:35 PM
  4. WTB Bellhousing
    By coolngroovy in forum Swap / Wanted to Buy / Trade
    Last Post: 27-12-2005, 12:32 PM
  5. wanted supra bellhousing
    Last Post: 24-09-2005, 03:30 PM
