Results 1 to 18 of 18
Thread: Series 1 and 2 differences
    Oct 2006
    Default Series 1 and 2 differences
    This has probably come up before but couldnt find anything with a search. What are the differences between the 2 motors?
    VP
    Oct 2006
    Adelaide, Blackwood
    dmitch's Avatar
    dmitch is offline DonkeySS
    VS SS S2
    Oct 2005
    Perth W.A
    90 VN SS 5speed, '90 VN Calais 5speed
    Jan 2006
    stanthorpe, qld
    i think you cant change the gearbox in the series 1 from auto to manual
    Adam
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    not much? theres heaps of little differences.
    cams are different(s2 less lumpy)
    s2 has holes in head for pcv
    rocker studs are different thread
    thermostat is at front
    exhaust manifolds are different
    s2 has plastic rocker covers
    thats all i can think of this early in the morning, but theres more, grab a gregories and look through the supplement in the back or search on here, the subject comes up every few weeks.
    _A_D_A_M_ joged my memory, s1 has a 6 bolt crank for autos and 8 for manual, s2 has 8 bolt all round.
    s1 has a rope rear main seal, s2 has neoprene seal.
    Aug 2004
    Quote Originally Posted by hakhawk View Post
    S1 does have plastic rocker covers.
    AP
    Aug 2004
    yeah, inlet manifold is different... different crank bearing design. Otherwise both engines are simiular.
    S2 normally has an plastic air restricter in the inlet manifold.
    AP
    hakhawk's Avatar
    Jan 2005
    Quote Originally Posted by AlpineRaven View Post
    AP
    vn s1 had alloy, at least both the s1 motors ive got had alloy covers.
    ive never seen a vn s1 with plastic ones, but maybe they changed em in s1.5 or you've just seen motors with em changed for some strange reason
    VN Commodore
    Feb 2006
    hakhawk's Avatar
    Jan 2005
    VN Commodore
    Feb 2006
    i got mine off ebay for bugga all. i forget how much now. but it wasn't much. i am only putting them on when i have finished stuff around with the car. otherwise they will get scratched and stuff..
    VP Executive R-spec
    Jan 2005
    My Lexcen 1990 has alloy rocker covers,VP's have plastic ones, a guy I knows VP has a hole in them from a angry spanner for proof:P
    VN Commodore
    Feb 2006
    ha ha.. that wouldn't be funny at the time i am sure.. well it would be funny for people watching..
    NORTI's Avatar
    NORTI is offline come get me
    VR Calais 5L, WM Statesman
    May 2004
    the rocker covers retro fit yes?? IE they will go onto Series 2 no probs?? they didnt change the mounts when the changed the cover materials?
    D.
  15. #15
    hakhawk's Avatar
    Jan 2005
    correct, they will fit series 2 aswell,but...(theres always a but) since series one had a different pcv setup, you will be left with a round hole about 15mm wide on the passenger side cover which needs to be welded up or a rubber grommet put in it.
  16. #16
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    the s1 manual uses a 6 bolt flange on the crank and is different to the auto crank, also the s1 and s2 cranks use different rear main seals and are not interchangable. s1 and s2 use different fuel rails also, s1 has black tube setup where the 2s used finned aluminum setup. s2 had a cam of slightly longer duration but less lift because the s1 produced to much torque from idle for the holden people although they produce the same peak power. as above different cooling systems and diferent intake manifolds etc. lots of little things but both are good. i have s1 manual exec and love it. goes better then my missus VS s2
    Body by Holden, Soul by Brock
    the Legend will live forever
  17. #17
    Aug 2004
    I had S1 converted to S2 engine (running VP wire loom in engine bay) in one of my past 91 VN. I have a picture somewhere.... will post it up sometime soon.
    AP
  18. #18
    NORTI's Avatar
    May 2004
    Dang I dont like the 'buts'
    D.
  1. V8 differences
    By zohpm in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-09-2007, 08:45 PM
  2. VY SS and VZ SS differences
    By hothouse vy s in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-09-2006, 12:33 AM
  3. VQ Stato series 1 & 2 garnish differences
    By Linchpin in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-07-2006, 07:28 PM
  4. VN series 2/VP differences
    By Wingnut0021 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-02-2006, 12:38 AM
  5. VT Series 1 & Series 2 Differences
    By Indy_387 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-06-2005, 03:15 AM
