Results 1 to 6 of 6
Thread: timing cover. do they have water jackets?
    VN Commodore
    Feb 2006
    Default timing cover. do they have water jackets?
    on the front of the timing cover on a series 1 motor. there is a place there that is flat. and has a bolt hole there. it looks like it is there for some sort of fitting that australia didn't need. if i drill into it to put my oil dump there. am i going to find a water jacket?? does anyone know. i would be thinking no. but i have never had one of these motors apart so i don't know for sure.
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    could be where the cam position sensor goes on the later models?
    got a pic?
    VN Commodore
    Feb 2006
    Doctor Bob's Avatar
    May 2004
    yep its the mounting pad for the cam sensor, you can drop oil back in there, but theres not a heap of clearence behind it though.
    depends on what sort of fitting you use
    Rob
    VN Commodore
    Feb 2006
    i had thought about a screw in fitting. then i thought of maybe using that bolt hole to my advantage. i might put another bolt hole in there bolt a flange to it. i don't know if one bolt hole would seal it enough..
    thanks for your help on that doctor bob..
    Aug 2004
    yeah its an cam sensor for Bosch computers 3.8 litre, not needed for delco computers. Thats from behind of my memory - could be wrong.
  1. Timing cover
    By furion in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-11-2007, 03:54 PM
  2. Timing Cover removal?
    By hispeedvp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-12-2006, 12:38 PM
  3. timing cover...oil pump
    By Meerkat in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-12-2006, 10:41 PM
  4. timing cover
    By callum87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2006, 07:52 PM
  5. timing cover
    By dave671 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2005, 11:09 PM
