Results 1 to 5 of 5
Thread: ignition problem
    gocatsgo1964 Guest
    Default ignition problem
    ignition problem in my vn commodore it is jammed and steering wheel is locked how can i get car back home for repairs as it stuck in town key will not turn to disengage steering lock will have to go back down and break ignition off steering wheel just to get it home hope that will work? any help with this problem would be welcomed thanks
    VP Executive S2 3.8L
    Oct 2006
    Kingston
    have you tried rocking the wheel to disengage the pin while you turn the key?
    Colin
    gocatsgo1964 Guest
    VP
    Oct 2006
    Adelaide, Blackwood
    turn it hard enough and you will break the pin that stops you from turing your steering wheel..
    once home replace the steering colum
    gocatsgo1964 Guest
    problem cured went to work on car this bloke working nearby with drill borrowed it and drilled ignition out which released steering lock took back of ignition off and started car with small screwdriver how lucky was that
  1. Ignition Problem
    By ELOSR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-05-2008, 01:24 PM
  2. ignition problem
    By blake0182 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-09-2007, 01:44 AM
  3. my VR problem, ignition?
    By ETH4N in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-09-2007, 06:16 PM
  4. Ignition problem
    By craigvk in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-01-2007, 02:52 PM
  5. Ignition Problem
    By jules in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-01-2004, 02:30 PM
