+ Reply to Thread
Results 1 to 5 of 5
Thread: --urgent-- dash not lighting up
    ben k's Avatar
    ben k is offline ben ben k Hitchhiker
    VP Calais S2
    Aug 2005
    radelaide...bay area
    Default --urgent-- dash not lighting up
    got a 100km trip to do tonite through the country...have a problem though
    my dash (speedo/taco/trip computer) aren't lighting up when my headlights are on....when i have my headlights off my trip computer lights up and as i switch it to parkers everything lights up for a sec but thats it
    is this a globe or electrical problem?
    bit dangerous/annoying when everything is pitch black and you don't really know what speed you're doing on the victor road which im doing tonite....thank god for cruise control
    any help appreciated
    cheers
    ben
    azkwazere is offline Ahhh Yes, Ahhh Yes.... azkwazere has disabled reputation
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    The only thing that i could suggest is that maybe the connector for your dimmer light is loose. Behind your clster surround (oval thing with buttons each side) there is a couple of light plugs/looms check to see if the loom plugged into the dimmer switch is secure. THe reason i suggest this is that that switch is a pass through to your cluster, if its not in, non of the daash lights will work (yes its happened to me....) Other than that im stumped!
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    dmitch's Avatar
    dmitch is offline DonkeySS dmitch Executive
    VS SS S2
    Oct 2005
    Perth W.A
    NORTI's Avatar
    NORTI is offline come get me NORTI Monaro NORTI Monaro
    VR Calais 5L, WM Statesman
    May 2004
    also check other fuses.... sometimes a blown fuse elsewhere will give a dash light fault, cant remember which one it was....
    D.
    VN Berlina
    Sep 2006
    i had the same problem mate...
    Fuse was the answer
    need a 5amp
+ Reply to Thread
  1. Led Dash Lighting
    By bdcmedia in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-09-2010, 09:09 PM
  2. Dash lighting FAQ.
    By Phreddy in forum ASR Audio & Electronics
    Last Post: 13-09-2009, 11:39 AM
  3. Dash lighting issue
    By G4orce in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-02-2007, 12:03 PM
  4. Dash lighting
    By MikesVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-08-2006, 12:45 AM
  5. Dash Lighting
    By Phreddy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 11-01-2006, 04:18 PM
