Results 1 to 15 of 15
Thread: power steering and brake pad question
    5sp VN Executive1988, VX SS 6sp
    Apr 2006
    canberra
    Default power steering and brake pad question
    First of all, the power steering pump pulley has a wobble. When it spins you can see that it is out of balance or something by a few mm's. Does this mean the pump is stuffed? Or bearings are stuffed? Do i have to replace the whole pump or can i just buy a new pulley? The pump also makes winding noises sometimes when turning at a slow speed.
    Now with my brakes. I have noticed that im in need of new pads. Im after some pads that dont make too much brake dust because im sick of cleaning my wheels every few days. And also would i have to get the rotors machined? or will it be alright to just put new pads in. The rotors are pretty new.
    Cheers.
    Australia. Love it or leave it
    xcop5l's Avatar
    xcop5l is offline 4th year spanner spinner
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    bendex ct's are a good general porpose pad and have verry low dust
    as for the p/s pump the wobble it as comon at the car its self. if you want to change the pump you re use the pully, i dont think changing the pully will make a difference
    Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
    MY RIDES
    [SIGPIC][/SIGPIC]
    http://forums.justcommodores.com.au/...ad.php?t=41837
    VN Commodore
    Feb 2006
    if the pump is starting to make noises it could be on the way out. they are pretty quick to change.. won't take ya long
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    also if its making noise it could be low on fluid
    MY RIDES
    [SIGPIC][/SIGPIC]
    Apr 2006
    canberra
    yeah i have to keep toping it up. Its got a leak. but i make sure its always full. And will i have to get the rotors machined?? cheers
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    its best if you do, it gives better stoping power when they are be in
    MY RIDES
    [SIGPIC][/SIGPIC]
    VN Wagon
    Feb 2005
    How come the disc look new but the pads are worn?
    In any case disc cost about $20 each to machine but you need to make sure they aren't close to the minimum thickness.
    New DBA rotors are pretty cheap these days particularly if you wait for a sale so often it is not much more expensive to replace the disc rotor.
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    Quote Originally Posted by TurboXS (Pete) View Post
    because the brake pad shines/poloshes the rotor then they become glazed and this makes the braking force less powerfull.
    new rotors are always a dull rough finish so the new brake pads have some thing to grab.
    the friction causes the steel in the rotors to become shiny,
    MY RIDES
    [SIGPIC][/SIGPIC]
    Apr 2006
    canberra
    Well im going by the lip on the outa edge of the rotor. There is hardly any lip so i guessed that they are not worn out much. Well no where near as bad as the rear. i know the rear needs new rotors. The lip on the outa edge is huge. i think they are still original rotors but the fronts are not original ones.
    Edit: and you dont have to change the rotor everytime you change pads do you???
    VN 5 spd/VR Calais daily driver
    Mar 2006
    NZ
    Quote Originally Posted by coolvncommodore View Post
    No, you're good to just do pads without rotors because the pads wear out much more quickly. Just replace the rotors when they reach minimum thickness or you warp or crack them.
    VN Calais no more
    Sep 2006
    If you have a power steering leak, i recommend LUCAS stop leak for power steering... works a treat.
    Dont like my driving? Get off the sidewalk!
    1988 VN Calais: CAI, 2.5inch Catback, 18x8.5shadow chrome wheels, JVC DVD player + 7inch Screen.
    Apr 2006
    canberra
    Is that the one in the white bottle? It has some guarentee to work? If so ive already put that in about 2 weeks ago. And i have to say its stopped the leak a lot. I think it still might be leaking very slightly but maybe over time it might stop all together.
    I ended up getting ferodo pads. Are they any good? I just went to supercheap cause i get a 20% discount there and ferodo were the best ones there so i got them.
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    frerdo pads make alot of dust
    MY RIDES
    [SIGPIC][/SIGPIC]
    Apr 2006
    canberra
    Oh dam. Hope they arent too bad. On the box it said low dust, thats why i got them. Oh well hope they are still alright. all the other brake pads at supercheap looked realy cheap and dodgy thats why i got the ferodo ones. They didnt look too bad
  15. #15
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Power steering pulley wobble . . . I got that problem too. Annoys the hell out of me. Surely it'd run smoother with a pulley that didn't wobble . . . Mine's on a freshly reconditioned pump from Holden Parts . . . I'm guessing that means nothing can be done about it.
    If anyone does have a solution to this, PLEASE PM me
  1. oil line from power steering to steering rack
    By onmy6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-12-2007, 10:08 AM
  2. VC power steering question?
    By Drewie in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 31-08-2007, 06:54 PM
  3. VH Power Steering..Trade For Manual Steering
    By vasrox in forum Swap / Wanted to Buy / Trade
    Last Post: 28-01-2007, 02:29 PM
  4. brake calipers. loss of brake power
    By VN-88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2006, 11:55 PM
  5. Power steering question.
    By Flange in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-11-2005, 10:39 PM
