Page 1 of 2 12 LastLast
Results 1 to 25 of 36
Thread: supercharger blowing out seals
    xcop5l's Avatar
    xcop5l is offline 4th year spanner spinner
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    Default supercharger blowing out seals
    ok today my cousin and i installed a super charger onto his s1 vn v6.
    the car is compleatly stock,
    the problem is whenever we turn the charger on it pushes oil out the rear main, it didnt have a rear leak before we started.
    i was just wondering if some thing has to be done with the pcv valve, we have ran the breather hose into the intake of the charger.
    also the first time we ran it with the charger switched on it blew the hoses off the charchole caniseter
    Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
    MY RIDES
    [SIGPIC][/SIGPIC]
    http://forums.justcommodores.com.au/...ad.php?t=41837
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    forgot to ad the pic, this is unfinished
    MY RIDES
    [SIGPIC][/SIGPIC]
    Boonz's Avatar
    Boonz is online now the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    i rekon its got a bad case of blow-by, how much boost is the blower running???
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    im not sure but id say about 4-5 psi
    the engine was rebuilt about 30,000kms ago so ive ruled blow by out of the equasion
    MY RIDES
    [SIGPIC][/SIGPIC]
    VP Exec,Gsx-R 750
    Mar 2005
    You are pressurising your sump by the sound of it. Maybe take your PCV hose out of the blower, eliminate that, even pull your dipstick out too. How are these blowers lubed? Have you blown the arse out of your oil filter at all?
    Are you sure its only running low boost........?
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    its only been on for today and its only just devloped the leak, it hasnt blown the oil filter apart,
    like i said im not sure what boost its running but the guy we bought it off said about 4-5 psi
    MY RIDES
    [SIGPIC][/SIGPIC]
    VP Exec,Gsx-R 750
    Mar 2005
    Might sound dumb, but is the PCV hose on the correct side of the blower? Its not pumping boost into your sump?
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    the pvc valve and hose are still conected to the intake, the breather hose is infront of the blower
    MY RIDES
    [SIGPIC][/SIGPIC]
    Boonz's Avatar
    Jul 2005
    have you check the pcv valve is working and unblocked???
    VP Executive R-spec
    Jan 2005
    You boosting the insides of you motor, move the lines to a non boost area
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    ok so if i block the intake where the pcv valce goes and run the pcv valve to the intake of the blower it should solve the problem
    MY RIDES
    [SIGPIC][/SIGPIC]
    VP Exec,Gsx-R 750
    Mar 2005
    You could remove the PCV from the system, just to determine if thats the prob. Its only a crankcase breather, just unplug it and see if you problem remains
    VP Exec,Gsx-R 750
    Mar 2005
  15. #15
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    ill try that tomorow arvo when i get a chance
    MY RIDES
    [SIGPIC][/SIGPIC]
  16. #16
    Matt_vp's Avatar
    Matt_vp is offline Donating Member
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    u should have a hose runing from where the pcv hose went into the manifold to the intake side of the charger. and block off the fitting where the pcv hose went into the throttle body. mine blows the smaller hose that goes 2 the charcol canister every now and then.
  17. #17
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    this one blew the hoses off the charchole canister strait away,
    also dose the breather hose from the rocker cover go into the intake of the blower 2?
    MY RIDES
    [SIGPIC][/SIGPIC]
  18. #18
    VP Exec,Gsx-R 750
    Mar 2005
    So long as its not on the pressure side of the system I cant imagine it would be a problem? No instructions with the blower?
  19. #19
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    nah it was just the blower and pully thats it.
    we had to make the pipes the brackets the intake plate the intake pipe bolts to. ect
    MY RIDES
    [SIGPIC][/SIGPIC]
  20. #20
    VP Exec,Gsx-R 750
    Mar 2005
    That sucks. Id just disconnect your breather\PCV system, try that for a start
  21. #21
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    well the plan is for it to go into the intake of the super charger, then i think its still epa ok because its not going into the atmosphere.
    but the vacume lines from the t/b aer going to be for the boost gauge and B.O.V
    MY RIDES
    [SIGPIC][/SIGPIC]
  22. #22
    VP Exec,Gsx-R 750
    Mar 2005
    I meant to disconnect it just for diagnostic purposes. At least if you know its in the PCV system (or not) it narrows things down for ya
  23. #23
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    the head srcatching part is the breather hose is already on the intake of the blower. youd think the breather house would stop the pressurising the sump
    MY RIDES
    [SIGPIC][/SIGPIC]
  24. #24
    VP Exec,Gsx-R 750
    Mar 2005
  25. #25
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    ok i didnt think of that.
    today was a bit of a rush and all we wanted to do was get it going so we could see what we did.
    it will hopfully be on the dyno in the next couple of weeks so we can get power outputs
    MY RIDES
    [SIGPIC][/SIGPIC]
  1. seals broken
    By VLACS in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-01-2006, 09:23 PM
  2. injector seals
    By vlrad in forum VL Holden Commodore (1986 - 1988)
    Last Post: 23-08-2005, 10:46 PM
  3. door seals
    By timboss04 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-08-2005, 09:11 PM
  4. Door Seals?
    By Shifty1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-07-2005, 10:58 AM
  5. window seals
    By sparkymac in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-06-2005, 04:19 PM
