Results 1 to 7 of 7
Thread: Labour to replace radius rod bushes - how much?
    93 VP Berlina Series II
    May 2006
    Default Labour to replace radius rod bushes - how much?
    Hey there, my radius rod bushes are rooted on the chassis and control arm ends. I've gone and bought nolathane ones, and a nice nolathane swaybar link kit while I was at it.
    Removed the control arm and front end of the radius rod from the chassis but there was no way in hell I could get the bush out so I put it back together again figuring I'll have to leave it to the pros.
    But the mechanic said $300 to fit - that seems a bit rich doesn't it? What's that, 6 hours labour? I could do it myself in 2 if I had access to a press. What are your thoughts and any recommendations on places to take the car in the inner west, and if you've had it done cheaper.
    dmitch's Avatar
    dmitch is offline DonkeySS
    VS SS S2
    Oct 2005
    Perth W.A
    u can buy a 500kg press for about 170.. saw it at supercheap once.. u could always go 2 a mech and get them 2 just put the bush in 4 ya.. then u can install it urself.. or u could use a vice with some wood and use that u press it in..
    Check out my ride and rate it high plz
    May 2006
    thanks man - that press sounds good. For that job really I needed a hoist too - I found a good mechanic willing to do it fairly cheap. Apparently it was a total bitch to get the bushes out (they needed grinders and all manners of things to get em out at the chassis end - no wonder I couldn't do it)... but it only cost me $140 and they fitted my swaybar links as well. Well worth it, there's some things I just can't do in my crammed garage.
    Drives heaps better. Nolathane rocks.
    VN Ute
    Oct 2006
    you an just use a bottle jack in your garage door frame to press them in/out, done this heaps with minis, holdens, cefiro, skyline works mint as, just dnt forget to smear them with a bit of lube/grease before you put the new ones in
    Japanese scientists have created a camera with such speed that they now can photograph a woman with her mouth shut!
    vn s2
    Jan 2006
    i have a vn and i cut my old radius rod bushes out and them the nolathane ones are 2 piece no pressing involed
    pandaman's Avatar
    pandaman is offline Aussie Muscle Fan
    VN Berlina 5.0 A4
    Feb 2006
    Quote Originally Posted by tug33r View Post
    I've heard mixed reports about the two piece ones. While they're very easy to install, apparently they can wear out quicker. I ended up paying to have mine done the old fashioned way, the trailing arm bushes needed doing as well so I decided that more than one set of bastard bushes could be someone elses problem. That was my birthday present to myself. End result: $500 lighter wallet, no more front or rear end knock, a very good wheel alignment and the knowledge that those bigarse rubber bushes aren't going anywhere anytime soon.
    Muttley, $300 sounds like it might be a little bit much just to fit radius rod bushes though, maybe just shop around a bit more see what you can find. If you got the two piece ones like tug33r, you can fit the new ones easily enough by yourself, it's just a matter of destroying the old ones to get em out.
    Beau Duke: Man, I'm never gonna get outta this car again. I'm gonna live in it, I'm gonna eat in it and I'm gonna make sweet love to it!
    Luke Duke: You mean you're gonna make sweet love IN it.
    Beau Duke: Oh no, I'm gonna have sex with it.
    J_D
    J_D is offline
    VN S1 and VS V8 Statesman
    Jul 2006
    Ipswich. QLD
    You can actually get the radius rod and bolt it in facing the front of the car and use it as a slide hammer. I did this when I replaced mine with nolathanes.
    Im not a complete idiot, some parts are still on backorder!
  1. VT-VZ Commodore Radius Rod Bushes
    By Huthy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-02-2012, 07:59 PM
  2. Radius Rod bushes
    By Mk III the HSV in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-02-2010, 08:59 PM
  3. how to radius rod bushes
    By bradvt98 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-04-2007, 10:20 AM
  4. Nolathane radius rod bushes
    By john41 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-01-2007, 09:17 AM
  5. VT Wagon Radius Arm Bushes
    By Swoops in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-06-2005, 07:45 PM
