Results 1 to 18 of 18
Thread: S1 better for working
    38VNIT's Avatar
    38VNIT is offline Azerium
    nothing
    Jul 2006
    Inverell
    Default S1 better for working
    I got told by 2 people the other day, series 1 vn motors are better for heavier working cause they ahve a stronger bottom end..?
    If you do things righ people wont know you have done anything at all...
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Hmm I think buicks suck.....
    I put a conrod straight through the block & ripped off a lobe on my cam...
    MaT
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Quote Originally Posted by HoZy View Post
    MaT
    with the exception of you i dont know anyone whose managed to break one of these motors or gearboxes, i know due to the low compression theyre good for boost however getting massive power NA out of these engines isnt easy youd be luck to spend $5000 working it and get 150rwkw??, s1 had a lumpier cam, but the only change to the bottom end i think was the rear main seal design, cranks a little diffrent (s2 can be convertered to manual) and just minor things, its not like were comparing a ecotec vs buick
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    I found shitload of cases in the US where people have thrown conrods out the side of the block... SNAP THEM AN BANG! BIG WHOLE/SIEZED MOTOR.
    VP Executive R-spec
    Jan 2005
    If you are going to run a strong NA motor with a cam, start with VR heads on either block.
    If you are going to run a strong boosted motor use EV6 (VP) block and heads
    VN v6 s2 Berlina 5spd
    Mar 2006
    what year did ev6 start?
    would a vn s2 block be ev6?
    are the vr heads higher comp?
    cheers ashz
    VP Executive R-spec
    Jan 2005
    Yep the series 2 VN is the start of the EV6 block and the VR heads had alot more compression (enough to run a decent cam)
    38VNIT's Avatar
    nothing
    Jul 2006
    Inverell
    well to put my question into concept, i was told basically because i have a series 1, that with certain few mods, that i could have a vn easy running safely at 7800rpm max, instead of 5500 (area)
    VP Executive S2 3.8L
    Oct 2006
    Kingston
    MaT
    Made for spectacular pictures posted elsewhere here on the forums though I see! Sorry mate, it woulda sucked when it happened, at least you were close to home!
    Colin
    'Ruby' 1991 VN Exec & '98 Proton M21 Coupe
    Chain Reaction Champion!
    Feb 2006
    North Tassie
    Quote Originally Posted by 38VNIT View Post
    Do mean as compared to the series 2 motor? Or compared to other commodore motors in general?
    :: hakhawk :: says:
    im a geek by day
    :: hakhawk :: says:
    a mass/axe murderer by night
    :: hakhawk :: says:
    and a rabbit sometimes
    I'm only nice to one person per day. Today is not your day....
    Tomorrow doesn't look good either.
    God must love stupid people, He made so many.
    VP Executive R-spec
    Jan 2005
    7800 rpm!:P that's alot of revs for a wobbly unbalanced V6 but anythings worth a try, just make sure you wear armour around your feet first
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    You'll need change the rev limiter aswell, I'm not sure about how to do that? but most VN's would self destruct at anything over 7000 without heavy modification
    bike :P
    May 2006
    so if i put vr heads on my vp id get what? (im putting a big cam in my car)
    38VNIT's Avatar
    nothing
    Jul 2006
    Inverell
    rev limiter is easy, but its the work envolved in doing it to get thatmuch lol, and compared to series 2, cause like i said this bloke has a vn s1 s and he said he put the s1 in cause an s2 doing that will just blow up lol
  15. #15
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    OUCH! 7800rpm? i aint no mechanic but i agree with greenfoam, in an inline i could see it happening, but in an unrefined, rattly buick v6? sorri m8 i aint calling you a lier, but it seems so hard to believe with something with a redline of 5500rpm, just one of them things id have to see to believe if someone done it haha ..... MAN! get a rotory if u luv revs hahaha btw good luck with that i want to see it when you do it lolz
  16. #16
    VP Exec,Gsx-R 750
    Mar 2005
  17. #17
    Johnsy's Avatar
    Johnsy is offline ★★★★★
    HSV R8 LS3
    Oct 2005
    C/Town
    Quote Originally Posted by Hillerus View Post
    Why would you wanna rev it so high anyway?
    To try and keep up with us
  18. #18
    VP Exec,Gsx-R 750
    Mar 2005
    Ha ha fair enough
  1. Fan not working
    By Old fart in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-10-2009, 05:50 PM
  2. Fan not working at all
    By stumps5L in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-12-2006, 01:25 PM
  3. Fan not working on VN
    By modcon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-04-2006, 01:20 AM
  4. Working a 202
    By macdooby in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-11-2005, 02:14 PM
  5. VK Fan not working
    By Kevin in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-02-2005, 04:41 PM
