HEy everyone
After getting my car back from being stolen, it was returned relatively unscaved. However the ignition barrel is stuffed as you would expect. My problem is that in the gregorys book it says to remove thwe ignition barrel from the steering column you must first put the key in and turn to on, then put a 3mm wire in some hole. My key wont turn. Is there any other way to get these things off?? Should i remove the retaining screw with a drill? any hints. It might be best to PM me to avoid other mebers cars getting stolen.
Stumps
pm sent....
