I have a problem with my V6 VP Calais.
When I back off the throttle while driving the car hunts/surges. The tacho bounces up and down a couple of hundred rpm and if I am going slow it makes my diff clunk (car has done 320,000 so diff/uni's are buggered) because it is bouncing up and down in revs.![]()
I have recently removed and cleaned out the Throttle Body and the IAC valve but this didnt help the hunting issue, in fact it just made the revs bounce faster.![]()
I have been told this could be cused by the IAC valve being set incorrectly (28mm if I remember correctly) or have also been told the o2 sensor may be faulty.
Anyone had a similar problem with the V6's?
Gotta get this fixed before I take the old girl over the pits.
could also be a kick down cable issue as i found with mine
~~Nic~ says:
yeah feel dick tho
get another iac valve and put it on the old one is probably full of junk in the steeper motor
Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
MY RIDES
[SIGPIC][/SIGPIC]
http://forums.justcommodores.com.au/...ad.php?t=41837
